pic of my blown IM gasket; replaced; still getting SES light. Ideas?
my mechanic showed me this today while he was changing my valve cover gaskets and intake manifold gasket and spark plugs
![]() bad news, still getting the "Service Engine Soon" light. what could it be?
1999 Chevrolet Monte Carlo LS [semi-daily driver until LIM repair or trade-in for '13 Fusion, 110k miles] Gone but not forgotten: 1995 Pontiac Grand Prix GTP[sold, 128k miles] 1996 Oldsmobile Cutlass Supreme SL Coupe [a minivan tore my door off, totaled, 84k miles] 1998 BMW M3 Hardtop Convertible [a pathfinder armada stopped in front of me, totaled, 70k miles] 1989 Chevrolet Cavalier Coupe [died, 160k miles, engine problems] 1990 Hyundai Excel GL [died, 220k miles, died] |
Re: pic of my blown IM gasket; replaced; still getting SES light. Ideas?
What code do you have?
i haven't had it read. the light only comes on when I'm idling.. red lights or just starting the car up and running it. when I'm moving it goes away so i assumed it may not have a code coming up
the check engine light will always come on at key on as a self test (so you know the light is working and not removed/burnt out. If this is the case, then it is normal. The only time the ECL is a concern is if it stays on constantly, goes on and off randomly while driving, or blinks rapidly during accelleration.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
also i checked last night, i'm still dumping oil after having the valve cover and intake manifold gaskets replaced. edit: i could have explained this better- the light STAYS on as long as i idle. when i shift it into drive and take off, it EVENTUALLY goes away. then it sometimes comes back on while i'm still moving, but ALWAYS comes back on when i stop at a red light. it also ALWAYS comes on when i'm driving above 50 mph
It sounds like you may have a bad oil pressure switch, oil pan gasket or rear main seal (all common issues on these engines. The oil pressure switch will cause oil leakage in the passenger side back of the motor area, the oil pan gasket will show leakage anywhere across the engine, and the rear main seal will show between the back of the block and transaxle (driver's side). As far as the CEL, you need to have it scanned and post the codes they find, as we could guess all day on what is causing that.
Just had the code read:
P0325 The mechanic told me it was a bad knock sensor. When I asked him about the oil leak he said it could either be unrelated or the o-ring on the knock sensor might have failed. Thoughts?
