Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-06-2011, 05:46 PM
ajsimon1631 ajsimon1631 is offline
Send a message via Yahoo to ajsimon1631
HELP>>>No oil pressure..replaced oil pump,filter..
We have a 1999 dodge 1500 conversion van with a six cylinder engine. we had no oil pressure last a year and a half ago, and we replaced the oil pump and it was fixed. now, the engine wouldnt start the other day, because somtimes it has a hard time starting when its very cold or very wet, and after messing with it for a day it started, but now no oil pressure, as soon as it started up we noticed it. we used starter spray to start it. but i dont think that would make it have no oil pressure at all. So we replaced the oil pump again and replaced the filter, cleaned the screen. and still no pressure at all. and the engine sounds like a diesel now. we have no choice but to fix whats wrong because we have 5 children, and ones in a wheelchair so we need this van, especially because my husband just lost his job, so we cant just buy another one. can anyone out there tell us what else could be wrong?
Old 03-06-2011, 06:17 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: HELP>>>No oil pressure..replaced oil pump,filter..
I wonder if there is something broken in the oil pump drive, such as a broken or distorted oil pump drive shaft
The Following User Says Thank You to MagicRat For This Useful Post:
ajsimon1631 (03-06-2011)
Old 03-06-2011, 06:43 PM
How would we be able to see that? and can that happen overnight, or just trying to start it? also husband says that he grabbed the shaft that goes to the pump and it was secure and didnt turn
Old 03-07-2011, 06:35 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
I suspect the oil pressure sensor.
Take the oil pressure sensor off and screw in a mechanical pressure gauge. Turn the engine over with the starter and see if you get some pressure on the gauge.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 03-07-2011, 11:03 AM
danielsatur danielsatur is offline
Symptoms of a cold hard start could be a bad, or dirty Massive Air Flow (MAF), or Incoming Air temp sensor.
I had a bad MAF/IACT sensor on my 1995 Towncar, it had a diesel effect when started in the early cold, if the engine was turned off, and restart she would be fine.
The computer, and engine got a little confuse with mixed signals from the MAF & H20 sensors signals.
You might consider a new oil pressure sending unit, and a new guage to check oil pressure.
No oil pressure to the hydraulic lifters would sound like a dodge diesel.
How many miles are on your van?
Do you buy a new, or remanufactured oil pressure pump?
Old 03-08-2011, 10:02 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
The oil pump is run by a shaft that is turned by the distributor, right?
If it is than why not pull the distributor and see what shape the shaft is in.
'98 Regal.... no oil pressure after changed oil Mr_D Regal 6 04-06-2010 12:08 AM
Oil pressure gauge roknjock2 Chevrolet Classics 11 07-30-2009 08:33 AM
97 Pontiac Trans Sport Oil Pressure light mspontiac Trans Sport 2 07-07-2009 05:52 PM
No oil pressure on my big block 454BLAZER Problem Diagnosis 10 05-22-2009 12:37 AM
2001 Denali Low oil pressure w/ engine noise diddy0230 Yukon 1 05-11-2009 07:27 PM
