Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 05-27-2003, 09:53 AM
lordvektra's Avatar
lordvektra lordvektra is offline
boost question
I know if I look around I can find this but im lazy right now how much boost can you safely put on a teg gsr with stock internals. I dont want a crap load of speed but just faster without throwing a whole lot of money into it? I was really thinking of a supercharger, maybe I can get the integra to make some bottom end also
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former."
- Albert Einstein (1879-1955)
Old 05-27-2003, 10:09 AM
PWMAN's Avatar
PWMAN PWMAN is offline
8-9 intercooled boost with pump gas (93 octane)
88' Dodge Shadow- 2.2L, 5 speed...a couple mods
[email protected] MPH
Old 05-27-2003, 10:12 AM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
cheap thrills, just get some Zex, or NOS, quick little boost for not much $$$, superchargers are kinda $$$ hungry and a turbo would give you decent $$ spendature, but I'd just stick a 50 shot of Zex or NOS for starters, you can do that safely without any internal mods (or many). anything beyond that and you'd probably want to build up the motor a bit.. if you are dying for a supercharger then I suggest you go look for a kit to fit your motor if one has been made.. personally I'd get a turbo though... I'm addicted to the hiss of a turbo..
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 05-27-2003, 11:34 AM
lordvektra's Avatar
8 psi? I was expecting a lot less with the GSR only about 5 or 6. how long could I run 8 without destroying something?
and as for the NOS, no thanks. all I need is a illegal, explosive tank in the interior of my car. I want all around power gain not just when I press the button. It’s a daily driver im not trying to do time runs.
Old 05-27-2003, 01:35 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
for daily driven i would run 5-6 psi so i wont mess up any of my internals. once in a while if you want t risk it you can turn the boose to 8-9 psi but if and when you do get a apex-i super afc so you can get enuff fuel for that extra air.
good times!
1
Shift_BOOST
97 s14
Old 05-27-2003, 04:48 PM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
yeah for daily driving get 5-6 and runfrom time to time a bit higher....just make sure you are always tuned properly(A/F ratio,timing)--->the most impotrtant thing
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 05-27-2003, 05:19 PM
91civicDXdude's Avatar
nitrous isnt explosive. its not a fuel. nitrous contains more oxygen than atmospheric air, so basically it just oxygenates the combustion process. If your car caught on fire and the nitrous tank broke open, it will fuel the fire, but it isnt explosive by itself.
Old 05-27-2003, 05:30 PM
lordvektra's Avatar
your right about not being a fuel by my thought is compressed oxygen in is self is quite flammable. I thought nitrous would react about the same
Old 05-27-2003, 06:17 PM
casperGSR's Avatar
casperGSR casperGSR is offline
Send a message via AIM to casperGSR
running 7lbs daily should be fine on your internals, for a while, but eventually you'll need to rebuild just like if you ran 5lbs... regardless of how much boost you run you'll prolly eventually need to rebuild to some degree.
Built and boosted...
"I feel the need.... the need for speed!"
http://www.automotiveforums.com/img.php?313283teggie2.JPG
Old 05-27-2003, 09:51 PM
lordvektra's Avatar
thats true of any car thats pushed, even factory so I understand that. but I just want to push what I can while keeping it as reliable as possible
Old 06-01-2003, 09:02 PM
super_man_3179 super_man_3179 is offline
Send a message via AIM to super_man_3179 Send a message via Yahoo to super_man_3179
I'd only recommend a supercharger if you had an automatic. Greddy sells cheap..well..inexpensive turbo kits...check that out if you want to just get more power without rebuilding the whole engine. they run about 5-6 psi which should be no problem for a daily driver.
JB
Old 06-05-2003, 11:48 AM
civicgsr_T4_60-1 civicgsr_T4_60-1 is offline
Send a message via AIM to civicgsr_T4_60-1
stock internal gsr w/afc,fmu,440cc's, 255lhp intank, and proper tunning. 10psi on pump gas, 15psi on C16 and that's with a T4 60-1.
00 civic with bolt-ons, i swear
