Go Back   Automotive Forums Car Chat > Audi > Older Vehicles > 4000/100/A6/S6
Old 03-02-2011, 02:19 PM
AtekorSFR AtekorSFR is offline
Exclamation 1989 Audi 100 Draining Battery
I have a 1989 100 5 Cyl, 4 Door, Automatic.
Everything works well in the car, Had the Alternator tested and is good, put out 14.2 - 14.8 volts. Battery is 6 months old.
When the car sits for a day without being used the battery is low and has to be jumped. Then there are no problems if I run the car about every 12 hours.
When I had the alternator and battery checked, I turned off the car and they said there is a lot of noise. Something is draining the battery.
I can pull the fuses to locate the problem.
Is there a meter or method of testing that when I pull the fuse on the circuit that is draining the battery, that I know I found the problem circuit.
i.e. Pull the ground cable, and put a meter between the cable and the battery and see what the draw is?
I am not sure what to do.
Any help would be appreciated.
Thanks
AtekorSFR
Old 08-30-2011, 08:53 AM
sammydose sammydose is offline
Re: 1989 Audi 100 Draining Battery
I probably had a similar with my 2006 A6, take it to the bank because there is probably something wrong with the electrical circuits that control the battery and everything else. The dealer look at it.
[Spam link removed by moderator.]
Old 01-28-2012, 08:12 PM
ricebike ricebike is offline
try the following link:
http://www.ehow.com/how_2249402_find...ery-drain.html
or any site that has similar process to find the parasitic battery drain
let us know if you found / fix it!
2001 gls battery drain jetta_help_needed Jetta/Vento/Bora 7 02-18-2011 12:37 AM
2006 Grand Prix Battery Drain wratchetjaw Grand Prix 9 12-20-2010 04:18 PM
1989 to 1991 Audi 100/5000 Bentley & AllData Manuals robandjeanne 5000/200/V8 1 05-17-2010 02:08 AM
2001 Olds Alero Battery Drain Issue Xenokira Alero 3 04-20-2009 10:04 PM
2001 Cavalier Battery Drain Problem - HELP amberdamber7 Cavalier Problem Diagnosis 25 03-25-2009 06:30 PM
