Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 03-02-2011, 12:49 PM
gordon_gjs gordon_gjs is offline
AF Non-Newb
3.8L (3800) Head Gasket Replacement Advice
A few weeks ago while driving home from work on the freeway I had some major engine problems. The car was very sluggish, loud, kept loosing speed until I had it pulled to the shoulder were it shut down and I had to coast to a stop. Alot of white smoke was coming from the engine compartment. Well after it was towed home (thank you AAA) I later discovered it was a blown head gasket. I pulled the front set of plugs out, turned the motor a couple of times to see a mixture of fuel and orange coolant get collected in plastics bottles I set in front of the engine.
So now that I know what is wrong with the car I started tearing apart the top end of the motor. Currently all is off the top of motor except the rear heads. These are the pictures how it all looks currently...
I know it pretty dirty right now, but I plan on cleaning it up. Judging by the way the heads look what would some of you experts recommend I do?
I called a 2 local shops and the 1st one quoted the following...
A. Shave and run the heads in the cleaner would cost $80 bucks each
or
B. Shave, run the heads in the cleaner, do a valve job and install new seals would cost $165 each.
The 2nd one quoted the following...
A. Trade in old heads for rebuilt ones - $150 each
of
B. Get old ones rebuilt, includes valve job, new seals, cleaning and shave for $150 total for both.
I heard somewhere that it is better to rebuild the orignal part then it is to put a rebuilt different part on it. So I am leaning towards B. at the 2nd shop.
Is there anything esle I should worry about when putting it back together?
What is the best way to clean the top of the cyclinder and get a smooth surface to ensure no leakage when put back together?
I also plan on getting the complete felpro head gasket kit from rockauto along with new head bolts.
Old 03-02-2011, 01:31 PM
j cAT j cAT is offline
Re: 3.8L (3800) Head Gasket Replacement Advise
with fixing the old heads if possible................
shaving the heads must be done to both heads exactly the same. then you must get a head gasket kit to replace this cut material..gasket will be thicker.
not doing this your combustion chamber will be smaller. this will require the use of higher octane fuel..
they the cutters and you must comunicate so that you can get the gasket for what ever they plan to cut.
The Following User Says Thank You to j cAT For This Useful Post:
gordon_gjs (03-22-2011)
Old 03-02-2011, 01:32 PM
danielsatur danielsatur is offline
If you got stretch head bolts, don't forget to replace all the head bolts.
The Following User Says Thank You to danielsatur For This Useful Post:
Old 03-02-2011, 02:04 PM
AF Non-Newb
I mentioned that to the guy at the shop, he ensured me that there will be so little taken off it will not affect the compression ratio and nothing special would be required. Maybe he told me resurface the heads. Is there a differance between shaving and resurfacing?
Also, my parts list includes...
- Felpro complete head gasket kit
- Head bolts
- Heater Core (old one is leaking)
and intake/exhuast valves if needed.
Old 03-03-2011, 08:11 AM
AF Non-Newb
I just notice that I wrote Advise at the end of the title instead of Advice...
Is there a way I can edit this?
Old 03-03-2011, 09:24 AM
- Head bolts
cleaning and shaving is different. any material removed will make the combustion chamber smaller. If this is being done because of the coolant entering the cylinder caused a distortion I would get heads off a scrap yard vehicle or new heads. you will need higher octane fuel and may find other issues with the heads cut/shaved and not adjusting for this. like more compression in the cylinders. could be engine not designed to handle this ..
Old 03-04-2011, 05:52 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
My question to you is did you find the bad spot in your head gaskets? ie: where it allowed coolant to fill the cylinders?
If not, take a peek in your upper intake plenum near where the EGR stove pipe goes. Look for melted plastic.
Part of my thinks pulling the heads was overkill as the Upper intakes on these motors fail causing coolant to fill the cylinders. I just hope for your case you didn't bend a connecting rod from possibly hydrolocking it.
Good luck!
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 03-08-2011, 09:54 AM
AF Non-Newb
Good luck!
I will check the upper intake plenum when I make it home today, but when I pulled the upper intake plenum off half a year ago I dont recall seeing any melted plastic.
I pulled the heads off because the middle front cylinder was blowing coolant and fuel when I removed the spark plugs while the others were not. The heads have also been leaking oil near the headers and I have also had an external coolant leak from somewhere near the heads.
How could I tell if there is a bent connecting rod?
In the last few pictures I posted you can see some pictures of the head gaskets, they are in pretty bad condition (from what I can tell). The coolant ports look almost completely sealed over. I could be wrong on this as this is my first time going this deep into the motor.
Currently the heads are at the motor shop being rebuilt and I hope to get them back tomorrow. If all goes like planned then I hope to have it together by sunday.
Also the coolant system on this car was neglected for many years before I got a hold of it. I have been trying to get it back to normal for awhile. Hopefully after this it will be almost back to normal. Somebody posted somewhere that running CLR instead of coolant flush cleans much better, is this true and safe?
Old 03-09-2011, 03:05 PM
AF Non-Newb
Re: 3.8L (3800) Head Gasket Replacement Advice
I recieved the heads and lower intake manifold back from the shop today all rebuilted and cleaned up. I will post pictures of how they turned out.
Also, Does anybody know if there is suppose to be a pencil size hole in the rear valve cover? I will also post a picture of this...
Old 03-10-2011, 11:52 AM
tblake's Avatar
In God We Trust
There should be no hole in the rear valve cover.
Your oil leak you mentioned in post 8 sounds like the bad valve cover gaskets, or the hole you mentioned above.
The external coolant leak could be numerous places, if it was puddling up near the injectors, more than likely your lower intake gasket.
To check for a bent connecting rod, if you still have the motor tore down, would be to rotate the crankshaft and watch the pistons move up and down to see if all of them reach the top of the block. If you put the motor back together already, I guess just hope for the best.
Old 03-14-2011, 09:46 AM
AF Non-Newb
Thanks for the info on the valve cover, I sealed the hole over with a rubber plug and some gasket sealant. I just wish I knew what put the hole there in the first place. I also rotated the crankshaft and all the pistons reached the top of the block.
This question here is for anybody who can hopefully answer it...
When the motor is unhooked from the front struts and is tilted backward or pulled foward, is it suppose to leak engine oil or transmission oil?
Old 03-20-2011, 02:39 AM
AF Non-Newb
Well I have eveything installed and when I try to start it just sputters for a second or so, back fire alittle and dies.If I hold the gas pedal alittle and start it will sputter and running alittle longer. Does anybody have any idea of what might be wrong?
I checked the IAC,throttle posistion sensor, all 6 exhuast pipes are hot.
I will check more stuff on it tomorrow, If anyone has any pointers please post or pm me ASAP! I need the car running by tomorrow night! Thanks!!!
Old 03-22-2011, 12:34 PM
tblake's Avatar
In God We Trust
Verify the spark plug wires are going to the right cylinders. Make sure the MAF is plugged in and you didn't forget to hook up your brake booster vacuum line. Check for Pending or Stored DTC's if you have an OBD2 Scanner. Just the things that come to the top of my head.
If all else fails, pull the plugs and look for coolant and run a compression check.
The Following User Says Thank You to tblake For This Useful Post:
Old 03-22-2011, 01:46 PM
AF Non-Newb
Yes, I finally got it started sunday afternoon! It was such a relief! I was sitting down thinking what could this be... I remember about the brakebooster. I plugged it in and it started right up. Now I am just fixing minor coolant leaks. I bought new coolant hoses today because the old ones are leaking. I also stripped one of the threads for the coolant thermostat housing. But I fixed it yesterday with a helicoil. Other then that the car seems to sound and run great. Here are some other pictures I took before putting it together...
I also found out were the hole came from on the valve cover. When I replaced the alternator last year I must have switch one of the longer bolts with the shorter one and it went thru the cover. But its fixed now.
Thanks for youre help!
Old 03-23-2011, 12:30 AM
tblake's Avatar
In God We Trust
Sounds Good and Good Job
That machine shop sure did a good job on your heads. Makes me almost want to change out my head gaskets just to get my heads to look like that.
May want to keep an eye on that back valve cover though as different materials expand at different rates and could cause your epoxy work to pop off. I don't think a replacement valve cover would be too spendy from a slavage yard should you ever want to replace it.
Last edited by tblake; 03-23-2011 at 12:35 AM. Reason: Spelling errors, late, buzzed :)
99 Windstar 3.8L Replacing Intake Manifold Gaskets dariem Windstar 8 03-21-2015 06:22 PM
95 Bonneville 3.8l vin.K wont start Tonedog Bonneville 41 01-07-2012 10:29 PM
Air bag code 44, Windstar 96, 3.8l kafkacell Windstar 0 09-07-2010 08:56 AM
2000 SEL 3.8l Battery Cable Hot !! Nox Windstar 2 06-12-2010 01:06 AM
96 Altima : Trouble Starting After Head Gasket Replacement EliteDistance Altima 15 05-31-2010 04:56 AM
