Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-01-2011, 09:07 AM
kevinmcknight92 kevinmcknight92 is offline
Baffled!
I have a '95 camaro. Its engine turns over but it won't start up every time in the morning. Changed fuel pump, filter, pressure regulator, pvc, air filter, and used injector treatment with plus gas. I also found a short in the fuel relay, which i think I took care of that because when its shorting I can't hear the fuel pump. Now I can. Wondering if the cam shaft sensor could be causing this problem.
Old 03-02-2011, 08:08 PM
izzydjinn's Avatar
izzydjinn izzydjinn is offline
Re: Baffled!
Does it crank normal as if its going to start but it doesnt?
Im assuming its a v6.
If it does, I would check the control module.
Is.... peanut butter jelly time, peanut butter jelly time, peanut butter jelly time, peanut butter jelly time.
Old 03-03-2011, 04:17 PM
Re: Baffled!
Actually, it does crank like it going to start but doesn't early in the morning. But after it warms up the car starts right up.
Old 03-03-2011, 10:34 PM
izzydjinn's Avatar
Re: Baffled!
Hmmmmmmmmm, weird. The reason I think it might be your module its because mine did the same thing as yours, and it turned out to be the module. Like you, my car would just crank awhile before it started. Then, after that, it was fine. But one day it just gave out, the module that is. And even at autozone, they tested it, and it showed it was fine. But since it was still under warranty I decided to swap it out.
