Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 05-25-2003, 11:28 PM
iceiso iceiso is offline
Send a message via AIM to iceiso
turbo/raising redline/floating valves
aight, i got a couple more questions...
1. Is it a good idea to raise redline on a turbocharged motor? vs NA?
2. What is a floating valve?
3. What parts do you need to upgrade to prevent it?
4. What is the process of actually raising the redline? (ie. hondata tuning and what to do)
thanks!
Old 05-27-2003, 09:47 AM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
unless you plan to reinforce the rods/pistons and basically every moving part in your engine I would suggest not going above the factory redline. you can, but your engine has a higher fail rate once you break the redline. More than likely one of the tie rods would snap off and dangle off the crankshaft and go through your oilpan on one of it's revs. Floating Valve is a valve that never closes from _--_ to ___ the floating valve never makes a complete seal thus the intake and exhale of the motor is pretty powerless (robbing you of power, and unexploded gases), which is why you should replace the valvesprings, and possibly the valves, and have them well oiled, and properly seated. if you do want to raise the redline, you should get a higer rated tachometer and just hook that up instead of your stock meter. ones rated up to 10,000 rpm you can buy at any auto store. but I reccomend you don't go too high above the factory rev limit, you risk blowing your engine. and after a certain point you raising the redline on a turbocharged motor the turbo will loose effectiveness the higher the rev range.. because the compressor fan can only spin so fast to drive the intake fan... higher revs will allow you a better shift change, and lower your times, but only to an extent.
good luck, anyone want to fill in on what I missed, and possibly something I said wrong?
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 05-27-2003, 04:45 PM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
to add to what kilah said be very afraid of floating valves....it can actually damage your engine.....it happens at very high rpm because the valvespring rates are not up to the job of pushing the valve fast enough back up....it can result in the camshaft lobes losing the contact with the valves
to compensate get some lightweight valves and high rate valvesprings
also the bottom end its important.....get lightweight but strong rods and balance the crackshaft....lighweight pistonts can help too
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
