Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 02-28-2011, 09:35 AM
LSC9901 LSC9901 is offline
2004 CRV Headlight Warning Realy
Could someone advise me as to the location of this relay ? It isn't working and I'd like to replace it before I inadvertently kill my battery.
Thanks.
Old 03-24-2011, 11:08 PM
pylet's Avatar
pylet pylet is offline
Re: 2004 CRV Headlight Warning Realy
I have a 2003 Honda CR-V and when my headlight warning buzzer didn't sound when I opened the door, I traced the problem to the door switch. If your interior lights don't come on and/or your "key in ignition" warning does not chime then the problem might be in the door switch.
It is located on the pillar between the front/back doors, covered with a rubber boot. I took it apart, cleaned it with a contact spray cleaner then tested it by grounding it against the frame and pushing the switch in & out a couple of times.
The interior lights came on, the headlight buzzer worked as did the "key in ignition" chime.
I figured the cause was because the seat belt retractor didn't retract the seat belt quickly enough and there were a couple of times I accidentally closed the door with the buckle hitting the door switch.
Hope this fix might work for you.
Old 03-25-2011, 03:57 AM
I wish the problem was that easy. It has been narrowed down to that relay/buzzer but I just don't know where it is. Not the biggest problem in the world but I have left the lites on a couple of times and didn't notice them until it got a bit darker out. Thanks for the response. Iwas beginning to think this forum was dead.
Old 03-26-2011, 03:55 AM
nailervette nailervette is offline
Send a message via ICQ to nailervette
Если Вам кажутся интересными онлайн игры, то карта аута ganjawars - это то, что Вам нужно. Проработанный онлайн мир, великие побоища, занимательные задания - все это Ganjawars. Мы не сомневаемся, что Вы влюбитесь в эту игровую вселенную. Чтобы играть, нужно всего лишь пройти регистрацию на сайте игры и начать набирать уровни. Войти в синдикат, купить топовые артефакты - все это позволяет исследовать мир с необычайным удовольствием. Играть в сию игру теперь можно не только дома, но и на рабочем месте. Просто требуется зайти в игру и наслаждаться игровым миром. Конечно же, если босс не заметит.
Old 03-26-2011, 06:23 PM
pylet's Avatar
Sorry to learn my suggestion wasn't a way of solving your problem.
Here is a link which may point you in a direction for help.
http://www.crvownersclub.com/forums/...ead.php?t=2360
Good luck!
Regards,
Pylet
Locked front brakes, brake light out, headlights gone kruqnut Problem Diagnosis 19 02-26-2009 08:49 AM
2004 CRV rear bumper reflector? amigo-2k CR-V 1 08-25-2007 10:15 AM
What Keyless remotes work with a 2004 CRV EX-L? JonoG5 CR-V 1 08-29-2005 01:06 AM
2004 crv tire question al colby Wheels/Tires/Suspension 1 11-23-2003 02:42 PM
2004 CRV springs? ScottSpi CR-V 1 10-10-2003 03:54 PM
