Old 02-27-2011, 09:53 PM
Larry208 Larry208 is offline
S10 front end noise
I have a 2002 s10 crew cab. 4.3, 4wd. 172,000 miles. I have a growling noise coming from the front end. Can't pinpoint exactly where. When I accelerate it disappears, and starts again when I let off the gas. If I put it in 4wd it doesn't make the noise. I replaced the front passenger wheel bearing hub, but that wasn't the problem. Help!
Old 02-27-2011, 10:22 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: S10 front end noise
What about the driver side bearing? Generally, wheel bearings can be identified while driving, when turning the wheel in one direction it will get louder and can seem to disappear when turning the other direction. Are you noticing such a pattern? With a driver side bearing failing, we would expect the noise to get worse while turning right.
Old 02-27-2011, 10:41 PM
The driver side bearing replaced a few months back. Turning the wheels either direction makes no difference.
Old 03-10-2011, 12:14 PM
j cAT j cAT is offline
If the hub bearing was making the noise turning the steering wheel would change the pitch.
most likely a drive train problem . check axles and those bearings.
what transmission in this ?
AWD Rear End NOISE BigBriar63 Rendezvous 1 05-10-2010 10:59 PM
90 GC front end noise Selec-trak benjaminbunny Grand Cherokee | Grand Cherokee SRT8 1 12-20-2009 06:00 AM
Creaking Noise At Front-End el ratfink Pacifica 2 12-05-2009 11:57 AM
Front end noise Bob Moore Dakota 5 07-25-2009 04:40 PM
Front End Metallic Clunking amesjm0431 Grand Prix 2 06-17-2009 09:17 PM
