Old 05-25-2003, 10:42 PM
slowcivichx97 slowcivichx97 is offline
more power less problems
IM THINKING ABOUT A B18C OR B18A SWAP WHAT CARS SHOULD I LOOK IN FOR THE EASIEST CHANGE AND SOME WHAT COMMON.
Old 05-27-2003, 12:35 PM
HXCivic97 HXCivic97 is offline
Send a message via AIM to HXCivic97
All B-series blocks will swap as easily as any other (with the exception of the B20, which you'd have to get a different head to allow it to fit under the hood).
The B18A1 will be by far the easiest to find, since it's under the hood of any '90-'93 Teg GS, which are all over the place.
The B18C will be harder to find, and therefore more expensive. Its donor car is the Teg GS-R (or Type-R if you wanna go JDM). The GSR uses a B18C1 (from 94-00) and the Type-R is powered by the B18C5. The C5 is generally about $1000-$2000 more. A lot of money for an extra 25 hp. (The C1 runs around 170 hp, and the C5 around 195 hp).
More common and less expensive, and just as easy to install is the B16A from an 99-00 Si. You might want to think about that instead of the B18. But it all depends on what kind of money you want to toss around.
Here are stats on the 3 engines i talked about:
B18A1:
Donor: '92-'93 Integra GS
Displacement: 1834cc
CR: 9.2:1
HP: 140@6300rpm
Torque: 121 lb-ft@5200rpm
Stock Tranny: YS1
B18C1:
Donor: '94-'00 Integra GS-R
Displacement: 1797cc
CR: 10.0:1
HP: 170@7600rpm
Torque: 128 lb-ft@6200rpm
Stock Tranny: Y80
B18C5:
Donor: '97-'98, '00 Integra Type-R (JDM)
CR: 10.6:1
HP: 195@8000rpm
Torque: 130 lb-ft@7500rpm
Stock Tranny: S80
Hope that helped
Old 05-27-2003, 12:36 PM
Re: more power less problems
By the way - next time do us a favor and leave off the caps lock. Just makes it look like you're screaming at us, and its harder to read.
