Old 02-27-2011, 11:02 AM
moliva1568 moliva1568 is offline
seat removal
I can't seem to remove this back seat. I'm guessing there's clips somewhere but I can't figure out which way to go. Any suggestions? It's a 74 pontiac catalina. It's a 6 door conversion but I believe the rear is pretty much stock as opposed to the added middle section
Old 02-27-2011, 04:44 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: seat removal
Have you checked the lower front of the seat bottom cushion for bolts or clip areas? Maybe try carefully running your fingers in the area between the carpet and the cushion to see if there are areas where things feel different. If you don't find any bolts in those areas, try pushing back on the cushion there and lifting.
Once you get the lower cushion out you'll probably find a couple of bolts holding a couple of tabs in for the rear seat back. Once you unbolt those you may just need to lift the seat back up and unhook it from the upper edge, or there could be a couple of bolts in the trunk.
-Rod
Old 03-15-2011, 09:45 PM
Re: seat removal
I'll try to have at it this weekend. I'm able to pull the sides back on the top part but I can't see anything back there.
Old 03-15-2011, 10:52 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: seat removal
You will find the bottom of the seat cushion, at the front, just above the carpet, has a wire frame inside. You want to push the wire frame backwards in 2 places.... about 10 inches in from the end of the seat, on either side. Push the wire frames back really hard in these 2 places while lifting gently. With some struggling, you will find the seat cushion will lift right out.
Then, if your car is like my old ones, you will find under the cushion, $10 in change, 6 old pens, half a Barbie doll and a dead mouse
Old 03-15-2011, 11:38 PM
Re: seat removal
Thanks for the tip. I've already found years of ashes and cigarette butts so the change would be welcomed. I'll keep my fingers crossed that a mouse is not found. It's bad enough I had to deal with the live ones in the hood of the caprice.
Old 03-21-2011, 04:42 PM
RidingOnRailz's Avatar
RidingOnRailz RidingOnRailz is offline
Cool Re: seat removal
A six-door conversion?! ! ! You've gotta post a full quarter angle of this car! Somethings' u don't see every day.
Old 03-21-2011, 05:54 PM
Re: seat removal
Purchased in Bridgeport
In case they wonder what it is
Old 03-22-2011, 11:41 AM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: seat removal
You don't see those every day Nice ride
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 03-22-2011, 08:30 PM
Thanks 4 posting! What a sight! How'z it handle?
Old 03-23-2011, 05:02 PM
Re: seat removal
It handles pretty good. Right now its in need of suspension parts and tires so I've been taking it easy. When I first got I could easily hit 90-100 in no time. I even took it to 75-80 with 12 adults in it once. Doubt I'll do that again.
Old 03-23-2011, 05:48 PM
Well by handling I hope you don't think I mean how fast it'll do a 1/4mile straight. With regards to steering, I'd bet even a "stock" Bonnie had at least 4 turns lock to lock steering. LOL! Guess you could put in a shorter ratio box and have a shop max the caster out within specs. Either way, some new bushings and that baby'll tighten right up.
Old 03-24-2011, 05:38 PM
MagicRat's Avatar
Re: seat removal
Three were in the trunk?
Old 03-25-2011, 05:53 AM
Re: seat removal
Didn't think you were referring to speed necessarily, was just throwing it in there. at that size, speed and weight it's still pretty tight. As youll find from posts I may put, I'm still pretty much a novice so some terms you may use or questions/answers I may have will reflect that.
No trunk actually. A couple females with some lapped up. It was a pretty wild night.
Old 03-25-2011, 09:39 PM
MagicRat's Avatar
Re: seat removal
Way to go.
If I had a 9 seat car, I would load it up with friends and chicks, too.
Wait! I do have an 8-seat full size Chevy van, with plenty of room behind the 3rd row............ lots of room for action......................hmmmm call some friends and fillies for Saturday night..............
oh yes, I also have a wife................ <sigh>
Old 03-27-2011, 10:18 AM
Sorry! "Lock-to-Lock" means how many times do you have to turn the steering wheel from the left stop to the right stop. Older cars could have over 4 turns, new cars 3.8 turns left to right or less even.
"Caster" = one of two alignment specs that when properly and evenly set(left to right) helps keep the car centered going straight ahead. Car is "tighter" with more Caster or SAI. Of course you might not notice these effects with a 70's Bonnie because the land-barges of her era typically overboosted the power steering to the point there was NO center feel/weight turning left or right. LOL! Too little caster(+ too much power steering, espec. electric) and you're constantly correcting. Drives me koo-koo!
Removing Back Seat farmers tan X-Type 1 09-22-2009 12:30 PM
98 camry back seat removal? heypauly Camry/Camry Hybrid/Vista 2 12-30-2003 09:15 AM
Rear seat seat removal. PLEASE HELP!! WithoutOnline Tires and Wheels 2 06-09-2003 12:01 PM
Seat Removal l2ice rocketz '88 - '91 Civic | CRX | Wagon | Shuttlee 23 01-15-2003 09:22 PM
Back seat removal DVS80R General Discussion 3 11-18-2001 06:26 AM
