Old 02-27-2011, 10:20 AM
TBmojorisin TBmojorisin is offline
GMC Jimmy Starting problems
When my 2001 GMC Jimmy sits for more than ten minutes, when I try to start it the starter cranks for about 5 seconds before it starts. If I let the fuel pump build up pressure first and the turn the starter it starts right up
Old 02-27-2011, 10:34 AM
brcidd's Avatar
brcidd brcidd is offline
Re: GMC Jimmy Starting problems
I'd hook up a fuel pressure gage and watch bleed down pressure after pump shuts off- does it drop fast-- like 60 psi to 0 in less than 30 seconds? You may have a fuel leak where you can't see it- like in the tank.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 02-27-2011, 01:48 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Inspect the fuel pressure regulator too, remove the vacuum hose running to it and look for any fuel contamination IN the hose, if you see any replace the regulator.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 02-27-2011, 10:04 PM
old_master's Avatar
Advisor/Moderator
The fuel pressure regulator is inside the plenum and does not have a vacuum line to it.
Check fuel pressure and leakdown: Ignition ON, engine OFF, fuel pump running: Pressure must be 60psi to 66psi and must remain above 55psi for 3 to 5 minutes after the pump shuts off.
As brcidd mentioned, the leak could be in the tank.... or it could be in the plenum. A pressure and leakdown test will determine if there is a leak, it will not tell where it is. The fuel pump must be isolated from the system immediately after the pump pressurizes the system, (and shuts off) to determine if the leak is in the tank or in the plenum.
You have to know how it works,
to figure out why it doesn't.
Old 02-27-2011, 10:55 PM
olopezm's Avatar
Oh I see, in that case I'm sorry for my mistake. I hope this problem gets fixed soon, I had a very similar problem and the it turned to be the fuel pump but I was advised to check the FPR that way.
Best regards,
Oscar.
1996 GMC jimmy surging 600cuin Jimmy 1 10-05-2010 06:37 PM
Blowing ECMb fuse 1990 gmc jimmy 350 bmxer20n Problem Diagnosis 1 07-10-2009 05:47 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
99 gmc jimmy starting problem theyard1 Problem Diagnosis 10 11-20-2007 12:02 PM
