Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Performance
Performance Anything you ever wanted to know about boosting the performance of your Cavalier.
Old 02-27-2011, 09:12 AM
ibfast2 ibfast2 is offline
need help with a 1997 supercharged z24
I just purchased a 1997 cavalier 5 speed the car has a supercharger on it already aftermarket fuel pump,bigger wires,bigger injectors,aftermarket fuel rail,header,egr is ran to header now instaed of block off.in short the car looks to be done rite.
#1 first issue no egr on the car and is throwing a low voltage code for the egr
#2 second issue if you ease in the throttle car runs great if you jump into it it bogs down at mid range sometimes you can make the car push threw the bog and it boosts great. Thats the reason for a new clutch this weekend putting a stage 3 ceramic in it with a 6 puck disc
So on that note any help would be greatly aprieciated on this small issue and again its a 2.4l supercharged
Old 02-28-2011, 01:10 AM
viggy58 viggy58 is offline
Re: need help with a 1997 supercharged z24
was the egr valve replaced when it was re-routed?
also, what do you have for exhaust? were the cat and muffler checked/replaced/upgraded?
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
The Following User Says Thank You to viggy58 For This Useful Post:
ibfast2 (02-28-2011)
Old 02-28-2011, 07:49 AM
the egr was eleminated has a header open exhaust and a big muffler at the tail with a removable baffle.There is no egr the aftermarket header bolts over the egr port.Unless im not looking at the right thing but i am pretty sure i am.Just so lost with this thing lol please help
Old 02-28-2011, 07:50 AM
the whole exhaust is upgraded
Old 03-02-2011, 08:29 AM
were should i go next to fix midrange boost
Need help with 1997 Blazer HAMcNeil Problem Diagnosis 2 11-20-2008 01:34 PM
need help with vacumm lines on Z24 engine for 89 nissan nissantruck Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 08-08-2004 03:34 PM
Need Help with 1997 Z24 Power Window Stall. ptuxbury Cavalier 1 04-22-2004 09:08 PM
need help with a 91 chev cav z24 that_girl1284 Cavalier 3 01-20-2004 12:29 PM
Need help with superchargers UberFurious Forced Induction 4 06-17-2003 09:22 PM
