Go Back   Automotive Forums Car Chat > GMC > Savana
Old 02-26-2011, 08:54 PM
luvnfl1 luvnfl1 is offline
2003 Savana fueling problem
When I go to the gas station to fuel up, I insert the fuel nozzle and as soon as I squeeze the trigger it trips off as if the tank is full. It does not matter how I position the nozzle or how far it goes in, it immediately trips off. I have tried many gas stations, no help. The only way I can get fuel into it is if I pull the nozzle ALL the way out of the fueling receptacle and barely & ever so slightly squeeze the trigger and basically just let the gas trickle into the tank...literally. The very instant that I insert the nozzle back into the tank..it trips off. It takes FOREVER to fuel this thing. I removed the fueling neck all the way down to the tank and the coupling hose. No obstructions, everything looks perfect, it's quite puzzling. I can stick my finger into the actual tank opening and feel a spring loaded poppet valve, it's not sticking and operates with just a small amount of pressure. Reassembled everything, no help. Thanks in advance for any advice, I do appreciate it.
fuel problem cbkdefaser04 Tahoe 4 08-16-2010 07:47 PM
help please. 84 yota fuel problems CBRrider Pick-Up 8 12-01-2009 08:16 PM
95 Aurora Fuel Problem? ffinoh Aurora 3 11-18-2009 02:43 PM
2003 Cavalier fuel problems hanginstu Cavalier Problem Diagnosis 1 07-08-2007 05:47 PM
2003 Cav fuel problems Wyno1 Cavalier 0 10-31-2004 07:45 PM
