Old 02-24-2011, 11:16 PM
jrecken jrecken is offline
seat back problem
I have a 2005 Lesabre Custom that I am almost ashamed to even ask this question but it is really getting annoying.
There is something in the drivers seat back that is moving around and is very noticable when stopping or starting.
Is there some way to get into the seat back to find out what is going on in there?
Thanks for any help or suggestions.
Last edited by jrecken; 02-25-2011 at 11:30 PM. Reason: problem resolved remove post
Old 02-26-2011, 10:56 AM
big white bufflo big white bufflo is offline
Re: seat back problem
i built seat for lear for 20 years most seat back were held together in the area were your butt sits with zippers or what is called a j- strap or j-and arrow if its jstrap to j-strap use a blunt object to pry the j apart then start sliding it along to seperate them if its j and arrow the arrow rolles then snap into the j it comes apart by un rolling the arrow part if its zipper take a pick slide it in to the part of the zipper were the little handle you pull on when you zip your coat up then pull the zipper should slide
VUE 06, Back seat problem Cheffo59 Vue 1 10-16-2010 11:08 PM
Need to remove backseat side back rests on 2004 I35 tgneid Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 09-21-2009 05:15 PM
Seat back will not lock back into position atoyota4x4 F Series 1 03-20-2007 12:22 AM
Center console on 40/60 seat - back seat? pnut333 C/K 0 09-05-2006 09:08 AM
Power seat switch won't move seat back or forward tim1950 Taurus | Taurus Wagon 2 04-11-2005 12:10 PM
