Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-23-2011, 09:49 PM
blueninja2000 blueninja2000 is offline
New-used 97 Rodeo
Just picked the truck up from craig's list for $500 has an oil leak and needs the starter replaced. Hoping i got a good deal has 244,000 mile on it. Oh yeah i just found out how hard the starter is to replace on the bad boy.
What you guys and gals think?
Old 02-24-2011, 07:38 AM
2000izusu 2000izusu is offline
Re: New-used 97 Rodeo
nice! auto or manual transmission?
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
Old 02-24-2011, 01:34 PM
Cat Fuzz Cat Fuzz is offline
I've said it before and I'll say it again, the easiest way to replace the starter is to unbolt the motor mounts, lift the engine with a floor jack and block of wood, remove d. side mount from engine, then you have all sorts of room to get it out through the wheel opening. Messing with the exhaust is trouble in the making. I can have my starter out in 15 minutes using this method.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
The Following User Says Thank You to Cat Fuzz For This Useful Post:
blueninja2000 (02-24-2011)
Old 02-24-2011, 09:08 PM
It's an automatic.
97 Rodeo 3.2 4x4/ 244,***
96 acura TL 3.2/ 270,***
94 suburban 5.7/ 170,***
Old 02-24-2011, 09:10 PM
Cat Fuzz, thats what im goint to try this weekend, so just the mount on the driver side is all that needs to removed or both side?
Old 02-24-2011, 09:46 PM
You have to unbolt both side from the frame, lift and then remove the d. side mount from the engine. You don't have to pull it all the way out, just set it aside.
Old 02-26-2011, 02:47 PM
Does anyone know a part number for starter bolt? Im missing the two and having a hard time finding them in a auto part store and the Stealership is close for today.
If you don't know the part nuumber does anyone know the size of them may pick up bolts from the hardwear store.
Thanks for any helps.
"I didn't loose the bolts bought it from the owner this way lol."
Old 02-26-2011, 06:29 PM
Well got her running looks like i have to do the valve cover gaskit next small oil leak.
Thanks again Cat Fuzz. Followed your instruction.
(eBook) Buying New and Used Car Tips schumi_reloaded Car Buying Q&A 2 06-05-2009 11:18 AM
Brand New 2004 Rodeo Help Please..... rodeo2004 Rodeo | Passport | MU 3 10-16-2004 02:38 PM
New 95' Rodeo Owner Bwzl Rodeo | Passport | MU 4 08-09-2004 08:44 PM
new useful website for new cars hanley Car Buying Q&A 0 07-11-2003 08:20 AM
New use for factory jack and oil change! ChuckH Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 10 12-14-2001 02:30 AM
