Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 02-23-2011, 03:24 PM
danielsatur danielsatur is offline
Tbl with 2002 Nissan Maima CEL!
Diagnostic Trouble codes -
P0139 - H20 sensor on bank1 sensor 2 (down stream)
P1147 - Heated O2 sensor 2
P0021 - Intake valve timing control
1) Replaced one bad HO2 sensor on bank 1 sensor 2.
2) Cleaned the cam sensor connections.
3) Reset + clear codes.
Old 02-24-2011, 12:58 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: Tbl with 2002 Nissan Maima CEL!
Mileage? Service History?
Swap plugs to denso/ngk iridium, and while doing that, DIY compression test (buy 20$ gauge)
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 02-24-2011, 10:38 AM
This car has 120k miles, so it's time for a new H02 sensor.
The owner had new plugs put in during a tune up, but that was it.
There's no CEL now, but it still needs togo through a drive cycle.
Old 02-24-2011, 11:13 AM
New plugs? If theyre B O S C H ...then theres your problim. Have to be replaced.
The compression tst gives also an idea how well valves seal. At this mileage there should be no problem there - but then also no valve related err code...
Coilpacks start to die after 100k. Only replacement helps when hiccup symptoms appear... ouch$
First issue is charge voltage, check at battery , then at ECU with a dmm (14.2-14.7V): Alternator is not the best part in maximas... Make a connector into cig lighter to keep eye on the voltage while driving: If fluctuating, replace alt.
Another issue is those battery connectors which stretch and become loose causing alt to fry and also causing nuisance error codes. Clean, Swap the connectors or improvise screw or whatever between the connector and pole to keep em tight...
The Following User Says Thank You to Nahkapohjola For This Useful Post:
danielsatur (02-24-2011)
Old 02-24-2011, 11:52 AM
Scrapper Scrapper is offline
AF Premium User
i would go to ngk and you can buy them cheaper at advanced auto zone don't carry ngk's and if you go to nappa or car quest you will pay double the price for ngk.
Tbl with a sticky Accelerator pedal! danielsatur Mariner/Mariner Hybrid 0 10-09-2010 08:46 PM
Tbl with BCM, causing a battery drain! danielsatur Grand Prix 10 02-04-2010 11:58 AM
2004 Rodeo with 3.5L DI CEL ALERT Rmasters3 Rodeo | Passport | MU 4 04-16-2009 02:39 PM
2002 Nissan Altima: Updated. DVSNCYNIKL Altima 4 04-13-2004 12:13 PM
2002 Nissans joshcoate Altima 2 01-11-2002 10:38 AM
