Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 02-21-2011, 08:06 AM
luxeryvic luxeryvic is offline
holley 600
hi, im lookin for a carb i can put on my 77 monte project without having to rebuild it. the engine is a 305 edelbrock performer intake mild cam and headers
the carb im lookin at it is a 600 holley that was running when taken off but it has been sitting in heated storage for a couple years
what are the chances of the seals being still good and just being able to bolt it on tune and run
Old 02-21-2011, 08:35 AM
MrPbody MrPbody is offline
AF -Advisor
Re: holley 600
A carb "sitting" for a couple of years will require a "kit", at minimum. Sorry...
For the dollar, your best "bet" would be one of those Edelbrock AFB "knock-offs". The 305 can do "fine" with a 600.
Jim
Old 02-21-2011, 09:44 AM
Re: holley 600
well the carb im lookin at is $75 and kits are cheap just ive been workin and tryin to get a q jet goin and even with a manual it is preety complicated and i cant seem to get it, ive heard holleys are easier to work on is that right?
Old 02-21-2011, 01:57 PM
Re: holley 600
also when i come to a choke wat wood you recommend the 75 dollar one is a manual and i can set up for either one. i plan on only drivin this car in the summer
Old 02-21-2011, 07:24 PM
denisond3 denisond3 is offline
Re: holley 600
I think of Holleys as being a little easier to work on, but its not a big deal. The q-jets were fine carbs, when new or if properly rebuilt. The same thing will be true of the Holley. What I like about the Holleys is having the float bowl vent tube sticking up inside the air cleaner. When my motorhome sits for months - i just pour a few teaspoonfuls of fuel into the float bowl vent tube, pump the gas pedal twice, close the choke, and presto; the engine starts instantly.
I prefer manual chokes. If you use an automatic choke, the bimetallic 'clock spring' element that senses the engine heat should be a new replacement. The original bimetallic spring ages over the years, and no longer swings with temperature changes as much as it originally did.
If possible I would use a plastic spacer under the carb, to isolate it from the heat of the intake manifold. And dont overtighten the screws on the carburetor assembly!
600 CFM Holley carb. drumcat Camaro Discussions 4 10-02-2004 11:06 AM
holley annihalator install appleboy Car Audio 1 07-08-2003 08:37 AM
Holley annihilator 800-200 gunnmen01 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 03-27-2003 05:18 PM
Edelbrock or Holley? 79_MonteCarlo Street Racing 27 10-20-2002 11:57 PM
