Old 02-20-2011, 08:02 PM
ipjkcu ipjkcu is offline
95 metro 1liter 5spd. advace needed
well rebuild the tranny. gears looked good. installed tranny quick hint this is a two part question.. first the clutch. by the way replaced that as well. the clutch peadal work when pushed hafe way in u push it to the floor and its slightly disengaged??? next one is second gear when shifting into or down to it works great intell you step on the gas then clicks the gears it does not pop out and i would say it grinds but it grinds if you try to hold it in gear it got me confused becuse it catchs when up or down shifting but as soo as u give it gas.. it like it pops out... advice tips hint or questions well be nice. and thank you all in advance
Old 02-23-2011, 12:07 AM
Re: 95 metro 1liter 5spd. advace needed
no ones got any advice..... well playing with it and driveing seemed to fix the clitch part of it but this second gear things got me bogled it shifts fine go in and going down it well grab the gear and slow you down but as soon as you give it gas it jumps out??? and you cant hold in gear. took shift leaver boot offf thinking it mite need ajusted. funny thing the shift lever is not like the one in the book its not straight then one angle its kinda of got an s to it... is that normall or has it been bent???
Old 02-23-2011, 05:33 AM
Metro Mighty Mouse's Avatar
Metro Mighty Mouse Metro Mighty Mouse is offline
The shift rods use steel balls under threaded plugs to hold them in gear. If you left one loose or didn't put the ball in then it will pop out of gear. Also, be sure to locktite all of the plugs that you take out or eventually they will come loose and it will pop out of gear again.
MMM
Old 02-23-2011, 02:31 PM
i was thinking maybe one of the springs is shot so iam going to take them out of the old one witch held in 2nd not sure what plug so i may have to change them all
Old 02-24-2011, 04:25 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
There was something else about second gear that needed to be replaced. I've seen this mentioned before, probably by MrMurph at http://geometroforum.com/site/. It might be second gear itself, the word cluster is insisting that it should be in there, I'm not sure. But if the synchronizer is worn badly enough then whatever it rubs against needs to go too.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
92 geo metro convertable center brake light needed imlippy2 Metro 1 01-13-2011 05:58 PM
Several Parts needed 92-94 metro swift pooptroop Metro 2 11-22-2010 08:15 PM
'98 metro 3cyl, 5spd - new owner snowninja Metro 10 07-09-2008 12:06 AM
FOR SALE 95 Metro 3cyl 5spd bbroski Metro 20 05-01-2005 12:37 AM
Looking at 87 GT 5spd --> Need advice/input blue88mustang Fiero 1 04-07-2005 07:39 PM
