Old 02-20-2011, 01:50 PM
airtight_python airtight_python is offline
'02 Silverado. CarMD says P0304.
'02 Silverado 4.3L. CarMD says P0304 - misfire on cylinder 4.
Misfire is most prominent when letting off of the accelerator at highway speeds and in low gear at higher RPM. Exhaust smells rich and fuel economy is poor. Wires and plugs were replaced at one point and the problem persists. Distributor cap and rotor also replaced. I run Seafoam in tank and through vaccuum once or twice a year.
I assume it's an injector sticking open, but where do I go from here rather than throwing money at it?
Old 02-20-2011, 03:21 PM
j cAT j cAT is offline
Re: '02 Silverado. CarMD says P0304.
how about a broken valve spring ?
Old 02-20-2011, 03:52 PM
slo99sierra slo99sierra is offline
I wouldn't think this unless oil flow had stopped. The 4.3 internals and other components are spec'd out like 350 specs - strength and durability wise.
Is it a persistent code? Does the SES flash?
Since it's an 02, I'd say the poppet valve is stuck open on cyl.4. Find someone with a scan tool that can do an Injector Balance (or with the spider injector system, the poppet valve balance) test and see what that does.
1999 GMC Sierra RCSB 4.3L V6 overall stock plus some exterior and interior work.
Old 02-20-2011, 05:53 PM
since this is just #4 or it could be any ONE cylinder , reports have shown this is where its defective the springs for some reason break on these engines. this is the 4.3L ..V6..
checking compression should confirm this , as well as the valve cover removal.
no compression you will get missfire !
Old 02-20-2011, 05:58 PM
SES comes on rarely. I can't clear the codes with the CarMD to see if it persists. The engine is slightly rough at idle at all times but not terrible. The missing does seem to get worse with the vehicles heater running.
Old 02-20-2011, 06:18 PM
Upon further observance I notice that the passenger side bank of cylinders has much more noticeable 'valve tap.' Cylinder 4 is center on this bank correct?
The valve cover gaskets are reusable if I am to pull it off for a peak?
Old 02-20-2011, 06:20 PM
when this totally craps out then it will be easier and no guessing or testing as well.
might have to replace the converters, as that unburned fuel will kill them.
Old 02-20-2011, 06:24 PM
??? Id rather fix it before it craps out.
Old 02-20-2011, 07:41 PM
If so check compression, check plugs and plug wires at this time . measure wire resistance in OHms should all be close in value.
if the compression is low remove the valve cover and check that the valve springs are good.. then it can get into head gaskets etc..
P0304 no spark from coil pack xavi.ordonez Taurus | Taurus Wagon 3 12-11-2010 02:59 PM
'02 Silverado Fan Speed Problem JMBonn Silverado 3 12-06-2007 04:56 PM
'02 Silverado, Leaking windshield wiper fluid reservoir Tdragone Silverado 7 05-23-2007 06:50 PM
Whacky Instrument Cluster '02 Silverado Blacksport350 Silverado 14 07-21-2006 12:58 PM
Test drove an '02 Trooper; can't say Ramblin Fever Rodeo | Passport | MU 3 06-25-2006 04:49 PM
