Old 02-19-2011, 09:47 PM
carl80 carl80 is offline
1997 s10 headlights
dim headlights. i used this as a reason to change them out and put in ones from the blazer. they work but are stil dim. the alt is good and i have read i need to check the ground. where would i find that at?
Old 02-20-2011, 06:59 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1997 s10 headlights
Black Ground wire can be found at the head light plug in socket.
Touch it with a grounded jumper wire and see if head lights come to life.
Report back what you find there.
MT
Old 02-20-2011, 07:57 AM
j cAT j cAT is offline
on these vehicles the headlamp connectors get corroded. you may have to replace them, possibly you could try to clean off the green coating on the fingers of the connector.
measure the voltage at the connector . this could also be a bad switch.
old lamps will not be as bright as a NEW LAMP! I would spend the money if the voltage is correct and get new lamps.
Old 02-20-2011, 11:37 AM
i replaced the plug when i put in the new headlights. when the car was off the lights had only 10v running to them. the battery is new and fully charged.
Old 02-20-2011, 01:32 PM
MT-2500's Avatar
AF - Advisor
Did voltage drop when lights on?
What was voltage to other things?
What is engfine runnibng voltage?
How good is the ground?
MT
Old 02-20-2011, 03:16 PM
measure the voltage from ground of the connector to the battery ground. if you get a voltage of any amunt the ground of the lamps is bad. if the voltage from the connector positive to the battery terminal ground is 10 volts and the ground is not defective then it would be the switch or connections to it / possible fuseable link corroded..............
you loosing about 2.5volts somewhere... battery voltage should be holding at 12.5volts engine off headlights on !
Disabling Automatic Headlights - 1997 Regal GS TrinaR1231 Regal 1 12-04-2010 05:37 PM
1997 S10 weird Problem Chevy7530 S-10 1 08-10-2005 01:48 PM
1997 S10 transmission DTCs bigred44 S-10 6 06-28-2005 07:57 PM
1997 s10 Blazer locowav Blazer 0 07-15-2004 09:05 PM
1997 S10 Door Bushing Replacement chainshot S-10 1 01-30-2004 03:44 PM
