Old 02-19-2011, 09:10 PM
viggy58 viggy58 is offline
97 sunfire 2.2L power loss and stall
hey guys. i post regularly on the blazer forum, but just picked up a 97 sunfire 2.2L auto trans for my sister.
I was driving it home to do some basic maintenance to it, and after about 40 miles it gave me some problems.
I came around a corner, onto a highway on-ramp, and when i tried to accelerate, it bogged down. almost felt like a coil pack went out, but it didn't throw a "check engine" light and i didn't hear any knocking. pulled to the shoulder and it stalled when i came to a stop. waited about 3 minutes, and it fired right up and made it the rest of the way home.
Before I bought the car, the cam and crank position sensors were replaced. From what i understand, this happened before, and those were the codes that popped up. I changed plugs, wires, and the oil yesterday.
thanks.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 02-21-2011, 02:45 AM
Re: 97 sunfire 2.2L power loss and stall
seems like the timing chain is going slack at acceleration.
i got codes for cam and crank sensors, which were replaced 100 miles ago.
you can hear the chain smacking around on acceleration
replacing the chain and gears tomorrow
while i'm in there i'm doing the water pump and oil pump. ill post the results tomorrow.
2001 Chevy Blazer
4.3L 5 speed manual
145k miles
146k miles
Old 02-21-2011, 11:05 AM
danielsatur danielsatur is offline
Also do a back pressure test on your catalytic converter, a plugged cat could choke your engine out.
Old 02-23-2011, 02:48 AM
the exhaust is good. it's not "choking out"
its def a loss of timing. the old chain def had too much slack in it, and the tensioner was frozen, so this should fix it. should have it all back together tomorrow...
2001 Chevy Blazer
4.3L 5 speed manual
145k miles
146k miles
96 Toy Camry LE 2.2L 5S-FE parts needed Maulana Classifieds 0 03-18-2010 12:17 AM
P0141 and P0171 codes 99 Sunfire 2.2L Rodc General Discussions 2 09-20-2009 12:20 PM
Power loss and stalled on interstate Staab '97+ 3 11-30-2005 03:26 PM
Total power loss and stall joiner18 Aurora 9 02-01-2004 06:36 PM
