Old 02-19-2011, 02:18 PM
kpabt0525 kpabt0525 is offline
Major anti freeze leak
99 GTP, 126000 miles. Major anti freeze leak passanger side bottom of engine. Near crankshaft area. Removed front right tire but cannot tell where it is coming from. Hoses are fine. Not a small drip, much more then that. Warm weather so shouldnt be a cracked block. Thanks
Old 02-19-2011, 02:48 PM
inafogg inafogg is offline
Re: Major anti freeze leak
water pump??/if its leaking bad you should be able to pressure test & locate
fairly easy.does it leak all the time or just when engine is running??you say
in/near crankshaft,the water pump should be right above this area.with a light
& a mirror see if its coming from behind w/p pulley
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 02-19-2011, 03:15 PM
Yes. only when running. From behind power steering fluid resevour. How do you axcess that area? Pull belts, alternator and pullys?
Old 02-19-2011, 03:30 PM
Also, it it be running out versus a small drip here and there?
Old 02-19-2011, 04:00 PM
do a search in gp forum this is 1 of many
GM revised the upper plenum in late 99, that addressed the commom EGR stovepipe failure on early 99-older Vin-K 3800's. The problem is that they still used the same JUNK gasket. If you see no external leaks, or if it has a small leak from the throttle body area (dirver's side), then it's most likely an upper plenum gasket failure, not a bad plenum. Another common coolant leak issue on the Vin-K 3800 is the plastic elbows that go from the intake to the belt tensioner on the passenger side. They get brittle with age, and will begin leaking only under pressure, then get progressively worse. At first, they will not leak enough to get on the ground, but you will smell coolant under the hood. The other leak area is the water pump casting. When the bearing seals fail, they will leak coolant out the "weep hole" and again, it will start as such a small leak, you may not see it on the ground.
Live For Today
Yesterday is gone,
Old 02-19-2011, 04:07 PM
It is a large leak when running. Close to a constint run of coolant. I think i will pull everything out down to the waterpump and see if the pump is the case.
Old 02-19-2011, 05:00 PM
Scrapper Scrapper is offline
AF Premium User
i'm thinking water pump also can you hear any bearing noise or squealing yet?
Old 02-19-2011, 05:09 PM
Do noise at all. Just a sudden MAJOR antifreeze leak. Replaced one on my 2002 tahoe but it was a very small drip type leak. What I have now is close to running antifreeze while engine is running.
Old 02-19-2011, 05:48 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Based on the location by power steering pump check the coolant bypass elbow on the back side of the tensioner. Also, the heater hoses pressure and return lines.
Can you tell if it is from above or the engine block?
Timeslip 08/12/06
AF Community Guidelines
Old 02-19-2011, 07:19 PM
AF Premium User
yes because it's under pressure with cap on it. if not water pump may have maybe frezze plug that rusted threw? i still think water pump if all hose aren't leaking?
Old 02-19-2011, 09:48 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Did you look into the coolant bypass elbows (two) as Bob stated? I'm betting thats your leak.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 02-21-2011, 05:50 PM
Well, you are all correct. Coolant bypass elbows. $20 for both. Probably saved me $250 to $350 with all your help. I really appreciate it. Thanks all of you for all the help!
GTP Anti-Freeze Leak bbaker1985 Grand Prix 2 04-03-2009 05:35 PM
anti-freeze leaking from the back kingmax718 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 08-09-2004 10:38 AM
anti freeze leake cavy4u2nv Cavalier 1 01-11-2004 05:33 PM
