Go Back   Automotive Forums Car Chat > Chevrolet > Lumina APV
Old 02-19-2011, 10:43 AM
Tony9972 Tony9972 is offline
exhaust manifold getting to hot melting tps
1994 lumina apv exhaust manifold getting to hot melting tps. what can i check change egr valve.
Old 02-19-2011, 11:30 AM
danielsatur danielsatur is offline
Re: exhaust manifold getting to hot melting tps
How many miles + when was the last tune up?
Could it be a plugged catalytic converter?
You can do a smoke test to check EGR system, PCV system, and air intake system, see
http://www.automotiveforums.com/vbul....php?t=1040765
Old 02-19-2011, 11:34 AM
http://www.automotiveforums.com/vbul...d.php?t=104065
197k did tune up plugs wires gas filter air filter. tried to connect to smoke test could not pull up
Old 02-19-2011, 11:44 AM
Old 02-19-2011, 11:49 AM
My Bad, see http://www.automotiveforums.com/vbul....php?t=1040765
Don't forget to check the cat's out too!
Old 02-19-2011, 01:15 PM
LMP's Avatar
LMP LMP is offline
I read about the smoke test:...wondered about the saran wrap first....then understood! next time I want photos! SHarp! ...I thinking about a substitute for the cigar.....
Tony, is exhaust escaping from EGR return tube ?....that is a 3.8, isn't it...
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 02-19-2011, 05:18 PM
If you don't smoke!
Plugged the air filter with glad wrap, and drop your favorate color smoke bomb down the air duct work befor hooking air box up.
You can manually open + close the throttle plate by hand to control smoke.
Old 02-19-2011, 10:11 PM
no exhaust from egr, yes its a 3.8
Old 03-04-2011, 07:51 PM
Exhaust manifold had a crack under the shield replaced it . Had no power at all replaced cat. Running good but check engine lite still on. Thres a way to check code how can I do it I heard I can put a jumper in and get code from engine light does any one know how
Old 03-06-2011, 10:42 AM
Jrs3800 Jrs3800 is offline
You will have to have a Scan Tool to check codes on your APV
It is common of the Tuned Port 91-95 3800 and the L67 SC 91.5 to 95 to crack the tubular manifolds... Glad you found that...
Old 03-06-2011, 11:30 AM
Scrapper Scrapper is offline
AF Premium User
did you reset the computer by taking of neg cable for about 15 mins then hook it back up see if it go's away? if it don't go out it may be o2's.
Exhaust Manifold gets RED HOT!!! Texan4ever Commercial Trucks 3 04-17-2006 03:26 AM
Exhaust manifold gets Red HOT! Texan4ever General Discussion 1 04-03-2006 04:44 PM
How hot does your exhaust manifold get? JekylandHyde Street Racing 14 03-21-2005 08:32 PM
Red Hot Exhaust Manifolds! earlroots C/K 5 12-11-2004 09:20 PM
Red hot exhaust manifold! earlroots General Discussion 4 12-11-2004 02:22 AM
