Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 02-19-2011, 07:33 AM
littlehoss littlehoss is offline
1997 jeep wrangler code p0340
engine stopped running, took to autozone and they got code p0340 camshaft position sensor A-circuit intermittent. sold me camshaft sensor in distributor still wont start. got book and claims it is crank sensor on flywheel housing. has any one had this happen to them and how did you repair it.
thank you
Old 02-21-2011, 06:15 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 1997 jeep wrangler code p0340
The Crankshaft Position Sensor (CPS) often starts going out as early as 90k and sometimes lasts well into the mid-100s. I had the CPS go bad on my 2000. If yours is the same, the CPS is located (if you're in the driver's seat) at the 11 o'clock position on or near the front end of the transmission. You'll need a long extension for your socket, but other than being tough to reach it's a straightforward job. In the Cherokee "FYI - How To" section, there are several descriptions of how to do it. Here is a link for you.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
The Following User Says Thank You to fredjacksonsan For This Useful Post:
littlehoss (02-22-2011)
Old 02-22-2011, 04:26 PM
thank you did that also put in new dist,crankshaft sensor,plugs,wires. took it to dealer they have had it for a day and a halve and still can not find anything. thanks for your help. hope they find something soon.
Old 02-27-2011, 05:36 PM
With all the new parts, I'd start checking wiring harness connections, and also check for worn wires, which could be shorting out and causing the issue.
1997 Saturn SL2-codes and what they mean emmaandleesmom SC/SL/SW 9 10-02-2009 11:53 AM
Wiring Diagrams for 1997 Jeep Wrangler idontknowcars Wrangler 0 12-03-2008 09:23 AM
350 Small Block bolt up to a 1997 Jeep wrangler stock tranny? Jester4904 Wrangler 0 03-23-2008 01:29 PM
1997 Jeep Wrangler Battery Meter Bkazoo Wrangler 3 10-20-2004 11:23 AM
