Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 02-18-2011, 08:34 PM
Cusser's Avatar
Cusser Cusser is offline
2005 Sunroof panel: fixed !!!
2005 Sunroof (OK, Yukon XL Denali) fiber panel had jammed somehow, couldn't get it to move into place, outer metal sunroof worked OK. After monkeying with it, letting my non-dealer mechanic look at it, "fixed" it by taking a cutter knife and cutting off the rearmost 1/2 inch of the fiber board. Now we can move the fiber board independently, and open it , and close it independently.
Methinks GM or someone over-engineered this, and maybe the fiber part was supposed to open automatically when the metal part retracted, but somehow had gotten jammed.
Old 02-19-2011, 02:41 AM
mishalah's Avatar
mishalah mishalah is offline
Re: 2005 Sunroof panel: fixed !!!
I have the same problem with mine...but I'm not sure what or where the fiberboard piece is.
Old 02-19-2011, 01:00 PM
Cusser's Avatar
The fiberboard piece is the coardboard-like panel that one should be able to slide back and let in only light, if one wants to have the glass part remain closed.
Old 02-19-2011, 01:28 PM
mishalah's Avatar
I assume it's the one I grab and try to pull forward only to have it move....nowhere?
What is keeping it from pulling forward? Some genius-developed piece of GM crap buried in there?
Old 02-19-2011, 07:28 PM
Cusser's Avatar
There's about a 1/2 inch upward ridge at the rearward side that gets caught. That's why I cut the rearmost part of that panel, that removed that upward ridge..
Old 02-19-2011, 09:44 PM
mishalah's Avatar
How do I get to the rearward part if it's stuck open?
Old 02-21-2011, 08:47 PM
Cusser's Avatar
When Mrs. Cusser (or GM) first got it stuck, the panel was stuck completely open, wouldn't close at all, and the sunroof itself wouldn't close either.
I took two pieces of coat hanger and made loops, and hled those in two vise grips,and pulled forward. It took a pirce of effort. Try to get a helper to pull down slightly on it, that migh thelp as well. After that, The auto sunroof would drag the panel back and forth, but wouldn't line up correctly. A month later, the mechanic looked at it, and when he said "maybe a dealer", that's when I decided to try this. So I made my panel into 100% driver-operated, while the glass sunroof is still automatic by the button.
Even my mechanic says: the more stuff, the more complexity, more to break. That's why I like my 1988 Mazda B2200 truck....good luck.
2005 Sunroof Cusser Suburban 0 10-12-2010 01:39 PM
Sunroof won't close PLEASE HELP ASAP Melaniemurph General Discussion 0 04-12-2010 08:43 AM
can a leaky sunroof be fixed? sarahinez Yukon 2 01-20-2010 06:08 PM
2003 Grand Am GT Sunroof not closing Sunfirepontiac2000 Grand AM 1 01-12-2010 03:47 PM
99 olds intrigue sunroof issue!!! smity9089 Intrigue 1 03-22-2009 09:21 PM
