Old 02-18-2011, 04:11 PM
ackard2 ackard2 is offline
new fuel pump/has power but doesnt turn on
2004 Grand prix GT2 :Ive changed the relays/fuses, changed the fuel pump, its getting the required 5volts but it doesnt kick on. Ive tried looking to see if theres a switch that kills the pump in case of an accident(no accident but maybe went bad) but havent been able to find out if it has it. Im lost, any advice
Old 02-18-2011, 04:33 PM
inafogg inafogg is offline
Re: new fuel pump/has power but doesnt turn on
inertia switch should be in trunk side panel behind carpet.
are you sure you have a good ground connection for pump??
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 02-18-2011, 04:50 PM
theres 5v going to the purple wire on the four prong harness but only .03v going to the grey wire, it is my understanding that the four prong is associated with providing power to the pump itself. I am unsure if the grey wire should have 5v as well.
Old 02-18-2011, 08:00 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
The purple wire is the Fuel level sending unit and with the connector unplugged you'll get constant 5v as the resistor in the level unit is not present (voltage divisor in electrical terms). If you connect it and backprobe the connector you'll see the voltage increase and drop depending on the fuel level.
YOUR PROBLEM is with the gray wire, that's the VCC signal for the pump and that's where 12v should be constant with key on, check the fuse panel for any blown fuses.
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 02-18-2011, 08:07 PM
olopezm's Avatar
By the way
Welcome to the forum!
I forgot to mention the electric diagram does NOT shows any inertia switch, the power runs straight from the fuel pump relay to the fuse box and to the pump. The highlighted wire corresponds to the gray wire in the first diagram.
Old 02-18-2011, 08:21 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Is the FUEL PP (fuel pump) relay energizing? Once energized by the ECM/PCM module the contacts of the relay passes B+ which is 12 volts to the fuel pump on the gray wire as olopezm pointed out.
Timeslip 08/12/06
AF Community Guidelines
Old 02-23-2011, 03:49 PM
The grey wire has 8-10v during the first few seconds when i turn the key on but then drops to 0 . I have checked all the fuses and replaced them just for kicks. Im lost on how to cure the problem.
Old 02-23-2011, 07:53 PM
olopezm's Avatar
The system primes the pump during the first seconds and turns off when you turn the key to the ON position; after that when you turn the key to the START position it will run the pump continuously.
Ask an assistant to hold the key at the START position while you measure the voltage, if you see it raise then it will be very likely you have a bad pump, there is a small chance you got a bad one right out of he box.
Best regards,
Oscar.
Old 02-24-2011, 09:16 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Hey Oscar, I'm not suprized. I think the inertia switch is just a ford thing. I know my 2000 GP doesn't have one but I've never worked on 2004+ so I didn't want to chime in and be wrong.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 02-24-2011, 09:18 AM
tblake's Avatar
In God We Trust
ackard2, before you remove the pump again, check the your ground wire (black), measure resistance between it and an unpainted metal part on the car. Should have 0 ohms or very very close to.
Old 02-24-2011, 09:23 AM
brcidd's Avatar
brcidd brcidd is offline
This happened to me once- put it all back together and went to prime system with primer lead--and nothing-- Got upset and beat the bottom of the fuel tank, and the pump started running. From then on, I always test new pump prior to install- don't want a bad one out of the box! Seems the new one was just stuck, from a long shelf life....as far as I know. Worked for several years there after....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 02-24-2011, 11:08 AM
olopezm's Avatar
Good one Tim, I guess I'm a little pessimist and like to go after the worst case scenario first LOL.
I know what you're talking about, even after I saw the wiring diagrams I was hesitant to reply saying there was no inertia switch, my 1997 GP doesn't have one either, but the windstar and the all-mighty TC both have the switch which is know to cause problems even when the car hasn't been in an accident .
Best regards,
Oscar.
Old 02-24-2011, 12:26 PM
danielsatur danielsatur is offline
Some newer Auto's have a pretection circuit for the electric fuel pump, if the fuel is too low, it will disable pump so you don't burn it up.
You can measure a volatge accross any open circuit!
If you bench test your new electric fuel pump, try to pump some fuel in a spare gas can for lubriication.
Old 02-25-2011, 11:50 PM
BNaylor's Avatar
And who gave the suggestion on an inertia switch? Speak up and please explain.
FORD - Found On Road Dead.
BTW - The problem is we have people giving their two cents worth on models (i.e. Grand Prix) they know nothing about or probably never owned let alone ever worked on one.
I'd say the 5 letter word starting with a "T" but I'll save that for a PM.
Timeslip 08/12/06
Old 02-26-2011, 10:23 AM
that would be me,after OP asked... my bad
also suggested the ground being checked
so PM me if you wish
Live For Today
Yesterday is gone,
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
'88 E30 has gone thru 2 fuel pumps! coons_7 3 Series 1 06-22-2010 01:16 PM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 09:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 08:04 AM
