Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 02-18-2011, 01:29 PM
rredwine rredwine is offline
Transmission problems
My son's 4runner blew a head gasket. I pulled the entire engine out and rebuilt it. I fingured that since I was in it, I minus well do everything. Now that the engine is back in and running, I went to put the truck in gear and nothing happens. I can put it in any gear, reverse, forward, etc. and it will not move. It is like it is in Neutral. I can roll the car but that is it. I'm wondering if I did something to the transmission when I put the engine in.
Thanks for you help.
Old 02-19-2011, 03:45 PM
OzzyO's Avatar
OzzyO OzzyO is offline
Send a message via MSN to OzzyO Send a message via Yahoo to OzzyO
Re: Transmission problems
Is the stick shift connected to the transmission and is there a chance the gear selector linkage on the tranny got moved while working on the engine ?
Just a suggestion.....
OzzyO
Old 02-19-2011, 10:06 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Auto or manual trans?
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 02-28-2011, 05:51 AM
slayer5's Avatar
slayer5 slayer5 is offline
My 95 V6 3.0 automatic trans is slipping also, but not as bad as you describe. The guy I bought it from had to replace a head gasket from an overheating issue that was happening for awhile. I replaced the radiator & thermostat...thats all it was. Runs cool now but tranny slippimg. My fluid is burnned so I am going to replace oil & filter to see if that helps. Tranny fluid is bad from clogged radiator.
Alarmed by website highlighting Honda Odyssey Transmission Problems LibertyLoudSpeaker Odyssey 1 07-09-2010 03:03 PM
2003 GMC Sierra 1500 5.3 Transmission Problem kkaupang Sierra 1 05-19-2010 09:58 PM
1994 Prizm possible transmission problem theginchico Nova | Prizm | Spectrum | Sprint 0 04-11-2010 12:52 PM
1995 3000GT Turbo manual transmission problem rene8603 3000GT/Stealth 8 10-08-2009 03:49 PM
Transmission Problem SeanCL Cobalt 3 09-15-2009 08:16 AM
