Old 02-18-2011, 08:54 AM
Zonic2001's Avatar
Zonic2001 Zonic2001 is offline
Urethane question...
This forum has been very helpfull to me, a new modeler and I thnk you all for that. But I have onther question to you all experts... Does anyone knows where to get "Engine Urethane"? That is the name of the non-yelowish urethane that someone in Japan that has a video in youtube was using. It seems to provide an extra clear and glossy layer than the normal Testor, Tamiya and other brands clear coats. If not, what type of urethane clear coating you all use? Thanks!
Old 02-18-2011, 11:19 AM
gpz900ra7's Avatar
gpz900ra7 gpz900ra7 is offline
Re: Urethane question...
The best clear coat for imparting the greatest gloss would be a "2K" clear coat.
Its a 2 part system, where you add 2 parts of the clear to 1 part of an activator, plus a dash of thinners just so that it flows nice from the airbrush, I asume you are using an airbrush?
The only drawback of such a clear coat is that you really do need to wear an oxygen fed mask, as this stuff is pretty nasty and will do your lungs a fair bit of harm if you don't.
gpz900ra7.
MY 1:1 toy
Old 02-18-2011, 12:32 PM
stevenoble's Avatar
Unless you are using the 2K clear with a full size spray gun on an industrial level everyday you don't need an air fed mask. Those full size guns really do emit some fumes, it's like a fog. I used to work in the car spraying industry and we did use an air fed mask there when using the 2K and it really was essential. Using it through an airbrush produces much less spray mist. If you have a proper, purpose made extractor and the relevant 3M spray mask, you can use it quite safely at home. I stress though that you do need the extractor and the proper mask. I would never spray it without those. It's not a case of spray it and you suffer irreparable damage to your lungs at the first usage. The symptoms build over time and end up much like asthma sufferers feel.
To answer the original question Zero 2K seems to be the urethane clear of choice for many, myself included...
Steve Noble
Old 02-18-2011, 02:10 PM
Zonic2001's Avatar
Where can I get the Zero 2k clear? Anyone in USA?
Old 02-18-2011, 02:52 PM
stevenoble's Avatar
You can't buy it in the USA, but you can order it from Hiroboy and I believe he will ship it to the USA, unless anything has changed..?? The Zero 2K is just re-branded Lecher product. Any 2K clear works in the same manner and will produce as good a finish as the Zero stuff if applied correctly. Have you tried to buy it locally to you..?? Most paint suppliers here in the UK carry it in their stock. Not sure if it's as readily available there in the US...
Steve Noble
Old 02-18-2011, 03:34 PM
Zonic2001's Avatar
I bet that there are similar products in the USA, I'm just new to this and don't know. Let see what others in here from USA tell us.
Old 02-18-2011, 03:49 PM
stevenoble's Avatar
I think a few of the US guys use Du-Pont brand 2K clear...
Steve Noble
Old 02-18-2011, 10:06 PM
360spider's Avatar
There are plenty of urethane clears (or 2K clears as some call them) for sale in USA. Du Pont is one, but there are at least a dozen other brands that make it. Stop by any automotive paint supply store, they should have it.
ItalianHorses.net
Old 02-19-2011, 06:58 AM
914joe's Avatar
914joe 914joe is offline
Zero will ship to the US. I use to use Dupont centari and now use Glasurit 923 2k clear. I need to buy at least 8oz at my local paint shop. You need really good ventalition, mask and need to cover all skin and eyes. The nastier it is the better it is
Old 02-21-2011, 05:32 AM
IanHug IanHug is offline
Steve, which is the correct filter to use in a mask?
Old 02-23-2011, 03:14 PM
Zonic2001's Avatar
Sellers in USA of 2k clear coatings are saying that their automotive products are too thick to get it thu an airbrush. Therefore, I told them I can dilute using thinner or any reducers they have compatible with their product but they don't feel comfortable that their product will look good thin down. Any comments from USA modelers? Need specific product names to get in the USA and if you please an estimation of how much thinner should I start with my trial and error spraying. If you don't want to post in here at least please PM me. Your help is greatly appreciated.
Old 02-23-2011, 04:47 PM
914joe's Avatar
I've used both Dupont and Glasurit clears thined @20-40% with no problems.
Old 02-23-2011, 10:22 PM
360spider's Avatar
Trust me, the stuff that you buy as 2K clear in hobby stores are EXACTLY the same stuff that you buy from automotive supply stores.
ItalianHorses.net
Didymus Didymus is offline
I think thinning is a durability issue that won't have any effect on modelers, unless you store your completed cars in the garden or in a sunny window. I think it's okay to thin it until it sprays right.
All the "biggies" make it: DuPont, Omni, PPG, Glasurit, etc. Last time I was at FinishMasters (a chain auto paint supply house), I noticed they had 2K clear in small quantities, like quarts. And I already have a respirator.
I remember having a hard time stripping it. But I remember seeing a solution on one of the forums. Steve?
It gives an extremely glossy finish that's not really correct for all cars. But I'll be building a Miura soon, and it would be just right for that swank machine. So I might give it another try.
D D M S
Old 02-24-2011, 09:02 AM
stevenoble's Avatar
This is the mask I use. No need to change any filters. You use it for a couple of months usage and then simply throw it away and replace it with another one. It's a 3M 4000 series...
Steve Noble
Another car stereo question Speculant Car Audio 11 08-18-2010 06:37 PM
2000 E150 question ZZT Econoline 1 11-25-2009 11:15 AM
exhaust question 89corollajoke Corolla/Matrix/Voltz 2 07-08-2009 11:22 AM
front urethane bushing question zimaad Aurora 0 06-16-2004 01:20 PM
Question about Urethane Front Bumpers? Masta '88 - '91 Civic | CRX | Wagon | Shuttlee 2 01-28-2004 06:34 PM
