Go Back   Automotive Forums Car Chat > Cadillac > General Discussion
Old 02-18-2011, 08:48 AM
MrBruce MrBruce is offline
Where is information on the Cadillac SLS model?
Hello, this one is driving me absolutely crazy.
I have a 1996 Cadillac SLS NorthStar with a 32 valve V-8 DOHC 4.6 liter engine with front-wheel drive type vehicle that was brought to me for a CAM shaft replacement.
I do not know why, but everything I find regarding Cadillac or GMC, I do not see anything on a SLS series.
This is NOT a typo, The letters are SLS.
I see STS and DTS and so on every where I look, but NOTHING on the SLS.
I can not find any service manuals related to this series for proper engine repair and specs on clearances and torque on engine related bolts.
I have tried getting information from other automotive forum boards on which repair manual best suits this engine, with no results.
Does this series exist, or is this SLS not a Cadillac emblem?
If someone out there can please help me to understand, why even this forum has no category for the SLS series?
Can someone please explain why there is lack of information on this vehicle on the web and in auto parts stores as well?
This vehicle is here in the USA, I do not think this is a foreign import to the best of my knowledge.
Which repair manual best suits this vehicle?
Thanks for any help in advance.
Bruce.
Old 02-18-2011, 03:02 PM
maxwedge maxwedge is offline
A990 racer
Re: Where is information on the Cadillac SLS model?
The sls is is lower trim model of the STS, the engine is still the N'star but somewhat less hp, same mechanicals for the drive train.
Old 02-19-2011, 08:12 AM
So this would mean that the STS service manuals would apply to this engine also?
By the way thanks for your reply.
Bruce.
Old 02-21-2011, 08:30 AM
caddydaddy caddydaddy is offline
Bruce.
For the most part, yes. Like he said, the SLS engine had less HP due to different cams, and the transmission final drive ratio is different than in the STS. Other than that, they are basically the same car.
These cars are really called the Seville. And there are two models of the Seville, the SLS and the STS.
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
Old 02-21-2011, 05:38 PM
Thanks for all your replies, this was what I was beginning to think, but wasn't sure.
This vehicle does not have the name Seville on it, just 32V Northstar SLS.
I think you have cleared up a lot of the mystery for me.
Just wish the engine number in the VIN # was more accurate.
I heard GMC messed up with the engine type in their VIN numbers.
The 8th character in the VIN is Y.
Bruce.
Old 02-21-2011, 05:49 PM
Scrapper Scrapper is offline
AF Premium User
Bruce.
have you checked your tittle or regeration to see if vin numbers are the same. if not you have a big problem? my dad tought me well.
good luck..
Old 02-21-2011, 05:58 PM
It won't say Seville on it, but the actual name in advertisements and possibly the owners manual will say Seville SLS.
Bruce.
VIN 9 is the L37 from the STS. An SLS would have the 8th character of a Y which is the LD8 engine.
2000 Cadillac STS
Old 02-23-2011, 07:06 PM
Originally Posted by caddydaddy View Post
Hmmm...VIN Y is the L37 from the STS. An SLS would have the 8th character of a 9 which is the LD8 engine.
The VIN # in the upper dash board area is the following:
1G6KS52Y7TU825505
8th digit is supposed to be the engine type.
For beginners I have the Haynes General Motors repair manual for the 1992 thru 2004 Seville #38032, the 4.6 L section of the manual is pretty accurate to this engine.
The cam that needs replacing is the left front intake cam.
That would be the one that the water pump pulley is pressed onto.
Bruce.
Old 02-23-2011, 08:16 PM
1G6KS52Y7TU825505
Bruce.
I mixed up the VIN characters. The LD8 is VIN Y, so that engine is correct for a Seville SLS. If you are replacing the cam, be sure that it is from an LD8 engine pre-2000.
2000 Cadillac STS
Old 02-24-2011, 08:19 AM
AF Premium User
good luck..
did you look at title tho and make sure vin number is the same? only other thing i'd know is they put diffirent moter in it. and if it came from a salvage yard they stamp the heck out of it before you take it. you may want to get a car fax because if your title like i say if vins not the same that's not good.
good luck..........
1997 GMC 4.3L Sonoma S15 SLS model X died mentat Problem Diagnosis 17 07-22-2009 08:13 AM
I'm in Tokyo...where are the model shops? spidereddie Car Modeling 13 03-31-2007 10:59 PM
where is the turn signal flasher located? 2004 model TNsportster Impala | Impala SS 1 03-05-2005 06:16 PM
where is the starter located on 94 sls ? will-20 Seville 2 01-21-2005 03:28 AM
Where is the Air Bag sensor for the 2003 Cav LS model Egememnon Cavalier Problem Diagnosis 1 12-18-2004 01:10 PM
