Old 05-25-2003, 04:49 PM
dxhatchback dxhatchback is offline
civic questions for newbie
what do i do for pistons, cams, cam gears, and headers for a ZC in a civic? i was thinkin D series pistons, D series gears and D series headers.. but what about cams???
Travis
HONDA is the BOMB!
Old 05-25-2003, 04:58 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Actually, the D-series cam gears will not work. You have to get B-series gears for the ZC and have them milled down by a machine shop, since they're too thick. D series headers will work, although the ports do not line up exactly, but can be easily made to fit with an air grinder. The D series pistons will work, but the ZC has domed pistons for higher compression, and any other D series piston will reduce your compression. I haven't heard of a good source for these. For cams, there are a couple of companies that make them, but they are terribly expensive, I don't remember who. There is a rumor that I've heard around that the B16 cams work and give you a wild cam profile, but I haven't gotten ahold of a set to see yet. Check out Hybrid and click on the link for the ZC for some really good info. This is the main resource that I use.
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 05-25-2003, 05:14 PM
what about aftermaket D series pistons? i am a parts dealer and i can get shit for really cheap.. and i can get JE pistons for the civic SI in 11:1 and i would think that they are gonna do some sort of upgrade?
Travis
HONDA is the BOMB!
