Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 02-15-2011, 08:38 PM
docksider docksider is offline
Cleaning Intake EGR Port
I have 90 v6 camry and I consistently fail emissions (NOx) - my questons: When I clean the intake port that mates with the EGR valve do I need to be concerned about damaging any sensors that may be in there? Also, should the port, when cleaned, be the same diameter as the port on the EGR valve? Most Gracious
Old 02-15-2011, 08:44 PM
danielsatur danielsatur is offline
Re: Cleaning Intake EGR Port
It's best to take off the throttle body to clean EGR gas passages.
Old 02-15-2011, 09:21 PM
danielsatur - isn't removing the throttle body a sensitive procedure? aren't there adjustments that i need to be concerned about?
Old 02-22-2011, 12:59 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Throttle body removal is pretty straightforward. There are no sensors other than the throttle position sensor that are mounted to the TB and as long as it stays attached and the linkage adjustments are not disturbed, there is no worries when reinstalling it.
The EGR valve is a vacuum-controlled valve only, there are no sensors inside of it. There is only a vacuum diaphragm. If it has a hole in it then it won't hold the valve open when needed. It can be tested in place with a hand vacuum pump...if it holds vacuum then the diaphragm is good. If the valve fails to open or close then the mechanism is stuck due to deposits. These can be cleaned with the valve removed using carb cleaner and a pipe cleaner to scrub away deposits.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
The Following User Says Thank You to jdmccright For This Useful Post:
danielsatur (02-22-2011)
Old 02-22-2011, 01:24 PM
Thanks for help, it's always good to have a 2nd opion, and set of eyes.
The Following User Says Thank You to danielsatur For This Useful Post:
docksider (03-05-2011)
Old 03-05-2011, 07:38 PM
Thanks all - i've been dealing with failed emissions for the past few years -- I'll clean the throttle body and replace the O2 sensor - I see an O2 sensor when I look thru the wheel well on the passenger side -- is there more than 1 O2 sensor on the 1990 v6?
cleaning EGR port susa2 Trooper | SLX | Bighorn | Wizard 4 04-19-2006 10:39 AM
Cleaning Egr Ports FIXMALL Windstar 5 12-21-2005 09:20 AM
Cleaned EGR ports tasteph Windstar 0 11-12-2005 12:47 PM
egr port clean done on 96 floridatgp Windstar 1 08-04-2005 09:57 PM
cleaning egr ports jwebb37 Windstar 0 10-03-2003 07:00 PM
