Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 02-15-2011, 07:00 PM
fp1529 fp1529 is offline
Knocking on cold start
I have a 99 suburban C1500 5.7 with 150,000 miles on it. Occasionally I would hear a slight tick when I started it, and it was cold outside. The check engine light started coming on about 3 months ago. I had it read at a local auto parts store and it was P1345. The light was intermittent and the truck ran fine so I did not address the issue. Several days ago the truck made a loud knocking noise during a cold start, the noise went away after about 30 seconds, sounded like it was coming fromthe left side of the engine. It makes this noise every start now and does not go away. I have not attempted to start it again because I do not want to damage anything. This sounds like a larger problem than I can handle. I am going to take it to a mechanic. Any ideas on what is wrong? And a reasonalbe cost to fix it? Thanks for your help. Only other thing I have done different is using Castrol High Mileage.
Last edited by fp1529; 02-15-2011 at 07:01 PM. Reason: More detailed vehicle description
Old 02-15-2011, 07:39 PM
j cAT j cAT is offline
Re: Knocking on cold start
this code is common with this mileage. the distributor has a gear to the cam gear. when this softer distributor gear is worn too much this is what can occur. it could be also the distributor bearing going causing this to get worn faster. since I have never replaced this there is much info on the internet with this engine and this problem..
make sure the distributor cam gear is GM OEM PART, if aftermarket this can damage the cam shaft..with the distributor is removed to inspect for wear of the gear the distributor bearing will show its wear possibly.if so replace both parts.
with your oil use 5-30wt or 10-30wt. no 10-40wt oil ! do not use FRAM oil filters they are poorly made. use wix, purolator plus, or ac delco ..
basicly the distributor and cam shaft are not in spec...............
97 S10 Blazer Hard Cold Start Problem Pilot423 Problem Diagnosis 1 10-14-2009 02:01 PM
93 Lincoln Town Car - Cold Start and Cold Run Issues blogsdon Town Car 1 08-14-2009 12:00 PM
96 Grand Am SE 2.4L Hard Starting Period Gman2007 Grand AM 2 04-13-2009 05:44 PM
Cold Start Knock (VVTi? patricia2217 GS300/GS400/GS430/Aristo 1 12-04-2004 11:42 PM
Cold start Engine knock SierraK1500 Sierra 8 06-18-2004 10:57 AM
