Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 02-15-2011, 06:56 PM
slade25 slade25 is offline
'97 Dakota 3.9L problematic stalling issue
Experiencing bad stalling instances and idling issues in Drive. When the truck is cold, the stalling is worse. Usually have to put it into Neutral at stops or in slow moving traffic.
Only diagnostic code I have is a PO783 (3/4 shift trans malfunction). This has been around for a long while. I did have the trans filter changed and fluid flushed approx 18 mths ago. 783 returned about a month later. Not sure if this is related to stalling problem, but a torque converter lock up issue could be. Hard to say if i have a tranny problem. Anyone ?
I have replaced wires, plugs, ignition coil, temp sensor and cleaned the IAC and throttle body. Dealership tells me I do not have an EGR valve, so nothing to investigate there.
During initial morning starts the truck sometimes sounds like there could a vacuum like issue, but am unable to locate any bad hoses, air leaks, etc. I suspected at one a plugged up catalytic converter but don't think I have that problem.
Another symptom is when the truck is fully warmed up, it works pretty good. I have almost no stalling problems and I seem to have most of the power (get up and go). Much different story when the engine is cold.
Can anyone help me eliminate potential problem areas or point me to where i should be concentrating.
Old 02-16-2011, 03:14 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: '97 Dakota 3.9L problematic stalling issue
the IAC motor is notorious for failing on these trucks; cleaning it sometimes helps and sometimes it doesn't. I'd throw a new one and see what happens. On a side note, kinda surprising that you don't have an EGR, I've never seen a 3.9 V6 w/o an EGR. Best way to tell is look on the side of the RH exhaust manifold, if you see a tube bolted to manifold, going to the back of the engine, then you have EGR.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 02-21-2011, 09:53 PM
zzGUY46 zzGUY46 is offline
I had this happen twice....both times it was a bad battery....good luck
'02 Dakota 3.9L cold starting problem TomKo Dakota 2 07-28-2008 02:58 PM
1990 dakota 3.9L wont start(need help asap) shiner07 Dakota 2 01-31-2008 07:06 PM
97 Dakota 3.9L transmission slipping fastlife1 Dakota 0 02-04-2007 08:36 AM
87 Dakota 3.9l Questions 87_dakota_man Dakota 0 04-15-2006 01:20 PM
Dakota 3.9L...Looking for help MM3DakQC4x4 Dakota 2 11-30-2004 10:31 PM
