Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 02-15-2011, 06:52 PM
stageone stageone is offline
Unhappy 1994 SW Clutch trouble
I had the clutch pressure plate and throwout bearing replaced less then 10k miles ago and it shifted as easy as always. The first sign of a problem was that sitting with the clutch pedal to the floor in gear the idle started getting just a little rough. Thats when I realized that if I took my foot of the break the car would creep forward. And also got hard to put in gear and when I did stuff it in gear the car would want to move even with the pedal to the floor. The oddest thing is that when the car is cold it works fine. The more I drive the worse it gets. But let the car sit a while and it works fine again till it is warm again. My guess is that the master or slave clutch cylinder is going bad, but how do I know which one? Is there some way to check rather than guess or replace both? BTW Im located in Michigan so cold is winter time cold. Like in the morning it is fine, by the time I get close to work, about 20 miles it starts acting up. By lunch its fine again till it warms up again and so on. Thanks for looking and helping if ya can!
Old 02-15-2011, 10:57 PM
Cat Fuzz Cat Fuzz is offline
Re: 1994 SW Clutch trouble
It doesn't matter which one has gone bad as they are replaced together. Also, you probably have water contamination. It would explain the difference in performance as the temp changes.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 02-23-2011, 10:23 AM
So if its water would it maybe help to just change out as much fluid as I can. They sell them seperate and the line seperate as well. Its goy 250,000 on it and I just hate to put any more money in iot then I need.
Thanks for the info
Old 02-23-2011, 12:34 PM
Scrapper Scrapper is offline
AF Premium User
Thanks for the info
i would just take cluch master and clean it put new fluid in it maybe twice bleed it again at the slave cylinder becuse you probably got water or tainted fluid in it. did you put new flywheel or did they turn the one that was in there because if it got hot and looked blue it needed replace.
Old 02-25-2011, 11:48 PM
The clutch hydraulics are very difficult to bleed. This is why they sell the system as a unit, pre-bled.
Old 03-04-2011, 06:11 PM
Being pre-bleadmakes it easy on me so I guess I will just bite the bullet and do it. It has served for 250,000 plus so it owes me nothing at this point! Thanks to all for the help It saves alolt and every bit helps!
Old 03-04-2011, 06:14 PM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Don't forget to come back and let us know how things are going once you have the work done! Good luck!
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 03-04-2011, 06:22 PM
I shall indeed. Gonna be moving as I need to be out of my old workshop by the 15th so the 1500 Z71 plow truck with be my daily (gas hog) driver till thats over and then i will get my little car fixed up. BTW where would I post about getting kerosene and the smell out of the back seat of the car. Had a space hearter accident and as time goes by the smell is getting worse! If I rub my hand on the seat it smells and feels greezy.
Thanks
JETTA Clutch Trouble... HELP! m007steve '97 - '03 0 08-02-2010 03:43 PM
1994 Cavalier trouble codes chubbybubba1 Cavalier Problem Diagnosis 0 03-07-2007 11:43 PM
1994 Lesabre Trouble Codes 321 and 361 jackfoxx LeSabre 6 12-09-2006 08:31 AM
1994 z24 trouble code 43 need help please glen r Cavalier 0 09-13-2005 06:06 AM
1994 Astro trouble Patricia740 M Bodies 0 11-04-2004 01:13 PM
