Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 02-15-2011, 05:59 PM
LvlyBstnGrl's Avatar
LvlyBstnGrl LvlyBstnGrl is offline
Red face Can someone help me?
Help! Help!! Help!!! I drive a Hyundai Sonata which just hit 100,000 mi last week. I bought the car in Dec. 2009 with about 82,000 mi. I work part-time and am currently a grad student so there is not a lot of $$. I decided to get maintenance work done last week, as I had the finances to do so. I got an oil change and a full transmission flush. I also had: Both rear sway bar links replaced Front brake pads and rotors replaced This was my first time going to this mechanic. Then I went to a tire chain and got two new rear tires as well as a balance and full alignment. I also had my front two tires wire brushed clean. The tires were not rotated. Two days later I got my car inspected. No problems. One day later a terrible noise coming from my car. Like a constant raspy moan from under the car. I also noticed that the wheel was still acting slightly bizarre despite all of the work. It was definitely better but still seemed slightly shaky with a slight pull. I have noticed that the noise starts at about 25/30 mi an hour. It is loud!!!! I brought the car back to the mechanic and he told me it is not the fault of the tire people nor the work that he did. I suspected perhaps the people at the chain tire warehouse mixed something up or broke a part. The mechanic said that the problem is the nut bolt inside of the front passenger ball bearing within the wheel/tire. I was told that it would be about $330 to fix. The part would have to be bought and then brought to a machine shop to be fitted. Machine shop's estimate would be $60 according to the mechanic with the part included it would be about $150. Then with labor included all the way to $330! Would it really take enough time to justify this labor cost? Does any of this seem right to you? I had absolutely no noise problem before bringing my car in. I had it checked thoroughly by this mechanic, checked at the tire place, and then inspected, all with no noise and no reported nut bolt in the ball bearing problem. SOMETHING SEEMS FISHY TO ME HERE AND I WOULD LIKE TO KNOW IF ANY OF YOU THINK IT DOES AS WELL? IS IT POSSIBLE THAT THE TIRE PLACE OR THE MECHANIC WORKING ON THE FRONT BRAKES BROKE SOMETHING OR BROKE THE NUT IN THE BALLBEARING? THE MECHANIC SWEARS THAT IT WOULD BE IMPOSSIBLE FOR HIS SHOP OR THE TIRE PLACE TO BREAK THE NUT BECAUSE IT IS WITHIN THE BALL BEARING. I Called another mechanic who is going to look at the car and he said that he never heard of a nut inside of a ball bearing. When I asked for my car back the mechanic wanted to know why and I told him I needed to get a second opinion. The mechanic then got very eore-ish and laid a major guilt trip about how he has treated me so good and he thought I would be a good customer- he can't believe I would turn around and do this to him. He put 45 minutes driving my car around today and so on and so forth. He asked me to promise I would bring my car back to him if the second opinion is the same. I think he was trying to guilt me into keeping the car with him and I think that also might be fishy. I just don't have money left to get ripped off after putting so much money into my car last week. PLEASE HELP! THANK YOU SO MUCH!!!!!!!!!!
Old 02-15-2011, 06:11 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: Can someone help me?
I have no response as to what your problem is, but a reputable shop should have no problems with a person getting a second opinion on an issue. If the second shop says the same thing, then it is your call on if you go back to the first shop for the repair or not.
The Following User Says Thank You to kris For This Useful Post:
LvlyBstnGrl (02-15-2011)
Old 02-16-2011, 07:27 AM
rallyman66 rallyman66 is offline
You are totally within your rights to get a second opinion on this matter. I would say the mechanic acted in a very unprofessional manner in the way he treated you after advising him that you wished to do so. It was after all the first time you had used him. It's not like you have a long business relationship with him. If he has nothing to hide I see no reason for him to react that way.
If you are going to this other mechanic and they come up with a different story than the first one and you feel they are trustworthy I might take it one step further and have them verify that all the work you paid for was actually done.
As far as the new problem goes noises are often hard to diagnose over the internet. It sounds like the mechanic is trying to say that the front wheel bearing needs to be replaced. That is possible but my experience with wheel bearing failures is that they gradually go over a period of time and you will hear a light humming noise that changes with the speed of the car. It is quite possible that the wheel bearing was damaged by the mechanic in changing the front brake rotors if they were rusted on and he beat them off using a hammer. There are other ways to remove rotors without damaging other components.
I hope you get this sorted out. Let us know the outcome.
I need help finding parts. Can someone help me or point me in the right direction? babygirl17 Mark VIII 7 09-17-2008 06:30 PM
can someone help me by telling me how to install a cd player? jonezer Car Audio 6 01-15-2007 05:57 PM
Can someone help me find this body kit? or a company that can make it? eclipseseeker Eclipse 2000+ 4 06-21-2005 05:43 PM
Can someone help me find this body kit? or a company that can make it? eclipseseeker Eclipse 2000+ 3 05-17-2005 07:34 AM
Can Someone Help Me out Eddiemm3 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 09-04-2001 03:26 AM
