How to adjust front doors
I have a 2001 Montana and both front doors are sagging. When closing the doors they are slightly lower than the loop on the frame. How do I raise the latch end of the door up so it won't hit when closing?
Re: How to adjust front doors
Is it the whole door sagging, or is just the latch off? Also, how much off is it?
I will check to see if the door is off or latch is out of alignment.
I checked doors and they are properly aligned when the doors are closed. When shutting the door, it seems to be about 1/16th inch low when it hits the ring on the frame. Can I adjust the ring on the frame?
I am not able to look at my Montana right now, but I think the ring is secured with a couple of bolts (maybe torx screws) that can be loosened enough to move it around. I think I would mark its location with a marker and then loosen the bolts just enough to move it a little and re-tighten. I would be worried about loosening too much and having things fall off inside, if they can. If this does not work and the ring does not seem to move, I would tap it with a hammer slightly in the correct direction.
