Old 02-14-2011, 09:50 PM
KairoCross KairoCross is offline
Need tips or advice for repairs
I purchased my car a couple years ago.
I had to replace the multifunction switch to get my brake lights to
work.
Now i am just wondering where should i start or begin with.
My headlights dont switch to day time running lights when the
key is on, the head lights and signal lights are always on.
Also the little screen that displays the boost and such is out, with
the clock and station part of the radio being out, but the radio works
normal, any suggestions?
2002 GTP Supercharged
Old 02-15-2011, 06:01 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Need tips or advice for repairs
Welcome to AF.
Visit our Grand Prix Tips & Maintenance forum for various tech tips such as getting the clock display on the radio back.
So your driver information center (DIC) is acting up? What else on it is not indicating properly?
Timeslip 08/12/06
AF Community Guidelines
Old 02-17-2011, 07:53 PM
Sorry for the late response,
Yes the DIC doesnt display, the clock doesnt show for the radio as well.
I noticed the 3 buttons beside the DIC turn on and flicker when my car
has been running for a while.
Also the switch for turning on my markers/headlights doesnt work at all,
my head lights are always on while car is running.
That about all the problems i have noticed so far.
Old 02-18-2011, 12:01 AM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Will the headlights turn on as soon as you start your car or they do until you release the emergency brake? If the answer is the second that's the DaytimeRunningLights and is perfeclty normal.
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 02-20-2011, 04:34 PM
The ebrake being engaged or not doesnt change the
headlights, once the key is turned the headlights are
always on full as if they were turned on, but the switch
is off, and if i were to turn them to the on position the
lights flicker once and stay the same
Old 02-20-2011, 09:44 PM
olopezm's Avatar
Maybe your headlight switch is bad, do lights turn off with the engine, or they will stay on for about 10 minutes after engine has been shut down?. Do you have any chime when you open the drivers door?.
Best regards,
Oscar.
Old 02-20-2011, 10:10 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
I'm pointing towards a bad ignition harness on this one.
http://www.automotiveforums.com/vbul...d.php?t=653340
Old 02-21-2011, 02:17 AM
Ill check the link in a moment, but no i have no chime and
the headlights turn off when the engine is shut off
Old 02-21-2011, 08:30 PM
also i noticed while night driving that
the switch is not illuminated at all
Old 02-21-2011, 10:04 PM
olopezm's Avatar
grandprixgtx00 might be right; do you have any other electrical gremlins like A/C not working, your key won't come out easily?
Old 02-21-2011, 10:09 PM
Unfortunately i wouldnt beable to tell if the AC would work
or not because the condeser was takin out after an accident.
But pretty much everything else is working as it should be
Old 02-21-2011, 10:20 PM
olopezm's Avatar
Sorry for the confusion I was tryibg to find out if your blower works on all speeds .
But if everything is working fine I would suggest getting a headlight switch from the yard and see if it fixes your problem it shouldn't be expensive. If that doesn't solves the problem then we'll have to figure out other electrical problems or a possibly bad ignition harness.
Old 02-21-2011, 10:58 PM
these all lead me to believe it is the ignition harness. Very common problem on the 97-03 GP which will cause all sorts of electric gremlins. I've been known to be wrong before, but this is an educated guess.
Old 02-21-2011, 11:56 PM
Well now that you mentioned it, it always seemed to
slip my mind that my fan works one 1-4 but not 5 it
just shuts off on 5
And sounds good ill look into getting a switch
Old 02-22-2011, 06:27 PM
olopezm's Avatar
Well that would be a good sign of a bad ignition harness like grandprixgtx00 said and since you haven't done it before it would be a good idea to replace it, it can't hurt to be ahead of more problems.
Best regards,
Oscar.
Fender Bender - Need Advice on Repairs Panken202 Grand Cherokee | Grand Cherokee SRT8 3 10-24-2010 10:50 PM
need some advice for suspension/car 93hase Accord/TSX/Accord Hybrid 3 03-26-2006 11:24 PM
Need some advice for my S2000 Bas Carwash Car Modeling 6 04-26-2004 06:22 AM
Need some advice for my xterra diversetek Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 5 09-08-2003 12:47 PM
Need some advice for this part of GTA: Vice City jon@af Grand Theft Auto Series 4 01-26-2003 06:21 PM
