Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 02-14-2011, 03:35 PM
stroise stroise is offline
03 malibu
Ok here is the prob. I cant unlock the drivers door with keyless enty. All other doors will work normal. I can unlock with key to get in. I can use the manual switch on the door to unlock and lock all 4 doors. When im sitting in the drivers seat and use the keyless entry to lock all 4 doors the doors will lock. When i use the remote the switch on drivers door wont move to the unlock position. Can the problem be a rod inside the panel. Can there be no voltage going to the latch to unlock the car but there is voltage to just lock it. Im thinking of getting a new latch at the boneyard. What do you guys think that could be the problem. thanks in advance
steven troise
[email protected]
Old 02-14-2011, 05:19 PM
brcidd's Avatar
brcidd brcidd is offline
Re: 03 malibu
The same two wires are used in either lock or unlock, just reversed polarity- so that is not the issue.
The thing I see is GM's lovely sluggish actuators- I have replaced many in pick-up trucks, and vans etc-- seems they get very slow and weak over time and I generally replace them with aftermarket actuators I buy online. They seems very strong and able to do the job.
So when you open up the door- measure the voltage at the actuator and see if it is fine-12 volts positive and negative-- if actuator is sluggish, you can try to lube the rod area- or check for obstructions, but most likely you have a weak actuator that needs to be replaced. I recommend aftermarket, only because they are much less expensive, and you should not get into the same problem as you would from a boneyard. Plus I doubt a boneyard would sell just the actuator--maybe a really good one would..
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
05 Malibu factory radio - adding MP3 xokayxo Malibu 1 09-22-2009 03:03 PM
2005 Malibu Maxx owners manual jkerr41 Malibu 3 07-03-2009 06:46 AM
03 Malibu Brake Issue frame1520 Malibu 1 03-01-2009 09:25 AM
2004 Malibu Classic vs 2004 Malibu LT classicsnw Malibu 9 08-07-2004 05:52 AM
2004 Malibu Maxx and Malibu Max SS Roadster2 Malibu 5 10-09-2003 11:25 PM
