Old 02-14-2011, 01:14 PM
crxdude91 crxdude91 is offline
how could i make my 91 crx hf faster??
how could i make my 91 honda crx hf faster..?? what would i need to change?
Old 02-14-2011, 06:10 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: how could i make my 91 crx hf faster??
Engine, transmission, ECU, suspension, & tires. After that it depends on your definition of faster, how much $ you're willing to spend, and whether you're capable of doing the work yourself, or have the $ to pay someone else to do it for you.
There are so many different options available. Dozens of different engines available. You could stick with naturally aspirated or go forced induction. You could be building the car for drag racing, road racing, SCCA, or just street driving.
Basically it's a very open ended question that you're asking.
Old 02-14-2011, 09:25 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
He speaks the truth, gotta narrow it down a little more than that. The HF was built for gas mileage, great light weight chassis to start with though.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 02-14-2011, 11:27 PM
GTA's Avatar
GTA GTA is offline
Whee..
What year hf? 88 is the lightest crx you can get and the perfect candidate for an engine swap which is the only way to get power outta an hf cause the stock 8 valve motor is very low in hp, so even supping it up won't do much.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 02-15-2011, 06:16 AM
Tony's Avatar
TLD Member #1
Not entirely true Greg...for the 2nd generation 88 might be the lightest, but got back to the 1st gens and they are insanely light, but at the sacrifice of the suspension.
Engine swap is the way to go, but where you want to go will determine what engine to go with. The D series have a lot of potential and usually pretty cheap to come by compared to the B series engines, which are good as well, just usually more expensive.
Tony
2000 328Ci - How to make it faster? Or should I get a G35? nshuman 3 Series 5 07-09-2009 01:31 AM
i just bought a 98' honda accord stick. How could i make it faster? ghostallu How-To's and Walk-Through's 4 07-23-2007 07:48 PM
how to make it faster. HeWhoKillz Corolla/Matrix/Voltz 2 05-08-2005 04:40 AM
wandering what i could do to my h22a swap to make it faster and stronger. need help extremeimportdude '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 42 04-26-2005 10:25 PM
How can i make my CRX faster and faster.. CrXb18c1 Engineering/ Technical 21 12-16-2003 10:28 AM
