Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 02-14-2011, 11:33 AM
bigryry bigryry is offline
Abs
Anyone have a problem having the OBD connect to the ABS system?
It will link with other codes but not the ABS.
Is the ABS module shot?
The abs light was on and i replaced both wheel bearings (they both were shot). The light is still on, I hooked it up to an ABS reader and it will not connect to the ABS Module but it will read other codes??
Old 02-14-2011, 01:33 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Abs
Are you sure the tool you're using is an ABS scan tool, or has the software to access the ABS system? If yes, then you might want to check the compatibilty of the tool to determine if it is compatible with the vehicle you are trying to scan. There might be an update for the tool that will allow it to access your truck.
What year is your Explorer?
-Rod
Old 02-14-2011, 06:03 PM
Re: Abs
It wasn't mine, i was told it was. It was a mac tool one i believe.. Not sure about which one but i will double check. I asked that day and was told yes
Old 02-14-2011, 08:27 PM
shorod's Avatar
SHO No Mo
Re: Abs
If it was a Mac Mentor it does have ABS capability, but the software needs to be updated for your model year.
-Rod
ABS to non-ABS curlybandit Regal 4 02-19-2005 11:44 AM
ABS problems.....ABS and Traction off light came on at same time Jeff2392 Bonneville 4 06-10-2004 07:04 PM
Another ABS question - ABS/Track turn on intermitently mtherr Windstar 2 03-17-2004 10:34 AM
abs light and humming noise from abs pump deaellis C/K 1 01-13-2004 05:10 AM
how hard is it to convert non ABS car to ABS? Quetzolcotl Engineering/ Technical 7 03-02-2002 06:18 PM
