Go Back   Automotive Forums Car Chat > Dodge > Avenger
Old 02-13-2011, 04:51 PM
rwilson46 rwilson46 is offline
alternator removal
My son and I are trying to change the alternator on his wife's 1999 Avenger with the 2.5 liter six. He has the alternator loose but we cannot get the thing physically out of the car. Are there any secrets we need to know? Do you have to remove the timing belt cover? He has removed everything that the Haynes manual says to remove.
Old 02-16-2011, 03:20 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: alternator removal
are you trying to get it from the top? Unless you remove the upper intake plenum, and remove all the necessary brackets, it's not coming out.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 02-17-2011, 11:33 AM
We've tried from the top and the bottom. We have taken the intake plenum and all the brackets off. It won't fit between the engine and the frame from the top. From the bottom it hits the cv boot and a post that is attached to the engine block for support of the alternator mounting bracket. Can't see how to remove that post. If we could get that off the alternator would come out the bottom.
Old 03-08-2012, 05:01 PM
bruce77x bruce77x is offline
I did the alternator in my son's 2000 Avenger 2.5 a couple of years ago. There was no easy way to get it out. It finally came out through the top, but only after turning and twisting it and finally hitting just the right angle by accident. Good luck and mind your language if there's kids around!
97 Grand Caravan Alternator removal todd_johnson9 Caravan | Voyager 5 10-30-2004 12:03 PM
1994 Alternator removal rlwillis Cherokee 1 01-29-2004 07:17 PM
alternator removal... jam4484 '88 - '91 Civic | CRX | Wagon | Shuttlee 15 10-29-2003 10:35 AM
91 Si Alternator Removal Aiwen '88 - '91 Civic | CRX | Wagon | Shuttlee 9 05-12-2003 08:50 PM
Alternator removal Cervantes Cherokee 0 04-22-2003 08:20 AM
