Old 02-13-2011, 07:40 AM
debra tucker debra tucker is offline
stalling out
I have a 96 dodge caravan that stalls out periodically what could it be
Old 02-13-2011, 07:55 AM
Alphabravo Alphabravo is offline
Re: stalling out
First off, from Steeler Country, congrats on a well-played Super Bowl.
Some more information would help, like engine size? Is the check engine light on? Have you checked for codes? Have you noticed a pattern when the stall happens, like when it's cold, or sitting at a light, does it re-start immediately or do you have to wait a while before it starts again, etc.
Old 02-13-2011, 08:43 AM
Re: stalling out
thanks for the congrats... The engine size is 3.3 the check engine light does not come on I changed the egr valve and cam sensor prior to this happening it stalls at a light even sometimes driving it down the road and sometimes it starts right away n sometimes I gotta let it sit for a couple mins bfbefore restarting I'm thinking maybe fuel pump or something else related to the fuel system
Old 02-13-2011, 10:01 AM
tempfixit tempfixit is offline
Re: stalling out
Are you saying that the engine dies while you are driving down the road or dies when you let off the gas pedal to make a turn?
Old 02-13-2011, 11:23 AM
Re: stalling out
Ya it just dies when I'm driving it or sometimes sitting at a light
Old 02-13-2011, 12:10 PM
Re: stalling out
What was the reason for changing egr and camshaft sensor?? Were getting codes and if so what were they and are you getting any codes now?? I would hook up a fuel pressure tester and tape to windshield wiper to moniter fuel pump. (Possible bad pump, if this happens again try tapping on the gas tank if you can with a rubber mallet and see if the pump works again). Could also be a crankshaft sensor that is heating up , then when it cools off again it works again.
Does this happen alot or intermittent??
How many miles?
Old 02-13-2011, 12:26 PM
Re: stalling out
How many miles?
The check eng light was on the codes were miss fire so we changed the sensors I haven't checKd for any codes since then cuz the light never came back on. Intermittent n 187000 miles
Old 02-13-2011, 12:41 PM
Re: stalling out
Do you have a code scanner or reader?? I would just check for codes again to see if there are any pending codes. You can also use the key dance to check for codes.on/off, on/off, on and the check engine light should flash( example---flash pause flash flash = code 12, 55 code means end of codes) or you may see a code number in the odometer if a digital cluster. Could also be coil but the intermittent is puzzling. Hopefully Alphabravo or someone else has a better idea. I am thinking if you needed to change the camshaft sensor I would also change the cranshaft sensor. They usually fail about the same time. without throwing any codes.
Old 02-27-2011, 01:24 PM
automps automps is offline
Send a message via AIM to automps Send a message via Yahoo to automps
Cool Re: stalling out
Had 1994 caravan 3.3 v6 do that same thing , New crank sensor & coil Fix my problem mind had a lot of miles on it.... MPS
91 Century Stalls Out smilen2894 Century 1 10-01-2010 02:43 PM
94 Mercury Villager Hard start - engine shakes - stalls out runnergirl262 Villager 6 02-12-2010 10:28 PM
1999 p71 cuts out temp light coms on, car dies/ stalls usedcopcardudenj Crown Victoria 3 08-09-2009 07:23 PM
stalling out backing out and when foot is off the gas pedel. JCL82 Breeze 1 01-30-2007 10:07 AM
93 Cherokee tries to stall, but never stalls out completey. Scott814 Cherokee 2 10-29-2004 01:51 PM
