Old 02-13-2011, 02:40 AM
ipjkcu ipjkcu is offline
transmission seals ???
95 metro 1 liter 5 speed black end cap.... ok so u got 5 seals with rebuild kit. you have your two small ones. shifter and in put shaft seals then you have three bigger ones...... one big one and one small one are for you axle shafts whats the other for. thanks for your help.
Old 02-13-2011, 04:06 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Re: transmission seals ???
There's one for the triangular plate on the bottom left side, but that's more of a giant O-ring than a seal. How about the top end of the throwout shaft?
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 02-13-2011, 09:00 AM
no the top of the shaft just has the bearing since you have the cover that bolt on. its the same kit doctorbill used in his post for tranny rebuild???
Old 02-13-2011, 10:26 AM
Woodie83's Avatar
What cover? I'm talking about the clutch release shaft, it's got a four inch arm hanging off of it that the clutch cable attaches to. Parts book shows a seal - 16x24x5, Suzuki Part # 09284-16004, same part from 95-01, my book doesn't include the earlier cars, but I can't see why it would be any different.
Woodie
Old 02-13-2011, 11:06 AM
that is not it. if u look at the first part of doctorbills transmission rebuild it show the same kit i have. and you can see the seals iam talking about. you know that the left and right side of the case have differnet size seals. well theres two that are the same size like i said i have 5 seals in kit 1 input shaft seal, 1 shift rod seal, 1 right side and 1 left side and i belive theres 2 left side??? theres really on four seals to change doing tran rebuild correct????? beside the o ring on cover plate for shift rod. or what u mentioned perviously. the cluth arm. iam just trying to figure out why i have a extra, or if its needed
how to replace transmission seal and oil pan seal goddardgrl Problem Diagnosis 2 07-08-2008 10:41 PM
transmission seal replacement gillers29 Jimmy 2 02-02-2005 07:36 PM
"94" S-10 Blazer: Main Transmission Seal madddank Blazer 3 08-13-2004 12:11 AM
Rear Transmission seal? Fmytruck Ranger | Courier 2 06-11-2004 09:19 AM
rear transmission seal johnsm Rodeo | Passport | MU 0 03-06-2004 06:23 PM
