Old 02-13-2011, 03:37 AM
tempfixit tempfixit is offline
idle rpm
Does any one know what the idle rpm should be for a 98 3.0??
Also what is the timing suppose to be set at??
thanks
Old 02-14-2011, 04:58 AM
kafkacell kafkacell is offline
Fooling around
Re: idle rpm
750 + - 850 RPM at idle.
Hyundai Elantra 2001 GLS
YOU ONLY
NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND
SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE.
Old 02-14-2011, 05:34 AM
Re: idle rpm
thanks kafkacell, I have ordered a cd service manual but has not arrived yet. I will adjust as mine idles @ 660 rpm at idle at normal operating temp according to my obdcom scanner on my laptop and timing is I believe 16.5% which I have read is none adjustable.
Old 02-14-2011, 10:46 AM
Fooling around
Re: idle rpm
Hi, IDLE is not adjustable. It's adjusted by IACV (Idle Air Control Valve). Maybe it's dirty. Remove it and use carb cleaner to clean the IACV.
regards.
Here you can see how to do it: http://leckemby.net/windstar/windstar02.html
YOU ONLY
Old 02-14-2011, 11:18 AM
Re: idle rpm
regards.
Thanks again kafkacell, I did not know it was unadjustable. I will clean, maybe that is why it idles a little ruff periodically.
Old 02-15-2011, 02:23 PM
Re: idle rpm
I cleaned the IAC and throttle body this morning, did not seem to make a difference in warm idle. Seems to idle a little smoother tho.
thanks
Old 02-15-2011, 04:05 PM
Fooling around
Re: idle rpm
You can test IACV by disconneting the cable with the engine off. Then try to start it. It should stall. Also with engine on disconnect the wire and idle should change and try to stall. Let us know the results, maybe IACV is bad.
Other symptom is when you are doing maneuvre park sometimes engine stalls.
Mine was really bad and engine stalled at every corner... cleaning did not help much, I had to change it.
YOU ONLY
Old 02-15-2011, 07:31 PM
Re: idle rpm
I disconnected the IAC, it wanted to stall but kept running just barely. Hooked the connector back up and it increased rpm and leveled out. I do NOT have any driveability problem so I am going to leave it go for now as there are other repairs that should be done first. 02 sensors, shocks, struts. thanks
91 525i idles at 5000 RPM!!!! HELP!!!!! Metalmatt87 5 Series 0 11-13-2010 12:09 PM
Nissan Cefiro - Idling/driving rpm problem fnasir Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 9 10-01-2010 11:35 AM
2000 Grand am se...bad idle and stalls weis_01 Grand AM 3 09-20-2010 12:50 AM
2001 Dodge Grand Caravan ES idle problem Rookie Tech Caravan | Voyager 3 07-03-2009 12:27 PM
Low idle RPM/rough idle and SES Doranpalmer Problem Diagnosis 1 03-23-2008 11:33 PM
