Old 02-11-2011, 10:02 AM
Macsplat Macsplat is offline
Ignition Arc Big Time
This is one I have never seen and am at a loss. I have a Manta Kit car. It has a HiPo 350 Chevy with 4 IDE Webers for induction. It also has a Mallory Electronic Ignition with a model 29150 coil.
Investigating what was thought to be ill-synchronized Webers I discovered 50% of the aggressive "pops" were not backfires through the Webers but rather rather electrical arcs across the manifold. Some upwards to 6" in length centered near or around the water inlet at the front of the manifold.
Any thoughts?
Old 02-11-2011, 03:58 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: Ignition Arc Big Time
I'm not familiar at all with your setup, but how are your grounds?
Old 02-11-2011, 07:42 PM
It's all pretty standard stuff. Battery grounds to the block. It is a fiberglass body so many components are grounded near their location on the tube frame.
Old 02-12-2011, 09:47 AM
kris's Avatar
I see. Yeah usually when I see arcing on newer model cars poor grounds are to blame, that's why I asked.
Old 02-12-2011, 10:30 AM
Thanks, Someone else built the car, thinking I will go through and check and re-ground all.
Thanks
Old 02-13-2011, 06:35 PM
534BC 534BC is offline
Are you saying that the secondary ignition wires are arcing to the manifolds?
Engine is mis-firing then too?
Most good wires can lay right onto metal and not jump thru.
Old 02-13-2011, 07:19 PM
Uncertain of what wire exactly. What I saw was; with a point of view looking straight down over the intake manifold. There was 1 - 6" arc and 1 - 3" arc emanating from the thermostat housing connecting to the two nearest manifold risers for the IDF Webers.
There was a subsequent backfire from the exhaust.
Old 02-14-2011, 04:22 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
My guess is that even though the block is grounded, it isn't the path of least resistance, that appearing to be through the coolant system instead.
Arcing from carbs can be a bad situation (gasoline present), so redo the block grounds to be as short as possible and using large gauge cable to provide the least resistance. Same with the battery straight to the frame.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 02-14-2011, 11:02 PM
Bad situation indeed. Here is what I have done thus far. Checked coil, (Mallory) for cracks, checked wires, (Accel) both are in good, clean and relatively new condition. Checked, cleaned and reset distributor ground, battery to block ground and added a clean battery to frame ground. Ground to bare metal, threaded a 5/16" for a stainless bolt to hold the 12" 4 Ga. to battery terminal.
While futsen with coil, the coil wire that mounts through a plate on the coil, low and behold falls off in my hand. "This has to be it", I think to myself. I disassemble, snip the wire for a clean contact and reassemble.
With confidence light her up. Sounds strong sounds clean. Let it warm up and let the Webers settle down back it out of the garage for a test and . . . there it is that painfully familiar orange tentacles from again thermostat housing.
Old 02-15-2011, 03:43 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Are the carbs grounded as well?
If they are sitting on risers they maybe insulated from the block, but picking up a charge somehow.
Old 02-15-2011, 04:06 PM
They are not grounded per say, e.g. there is no ground wire attached to them. Though the arc from thermostat housing goes more after the towers, which are 3" tall themselves. Though I can certainly try that.
97 Safari turns over but won't start - ignition coil wires? icemuncher99 M Bodies 3 05-31-2010 06:03 PM
ignition coil, big deal? duckfart Performance 0 01-15-2006 12:28 AM
I Need Yall Help Big Time ( Urgent ) Speedy Gonzalous Street Racing 7 12-14-2001 02:55 AM
People I Need Your Help Big Time (URGENT) Speedy Gonzalous Street Racing 0 12-11-2001 10:20 PM
