classic forces to speed up
hey guys i have a 2005 chevy classic, 2.2L, in the past two day the engine lite came on and it started like it wanted to turn off or choke when i give it gas. well today comein from skool it started to force it self to run.... evry time i give it gas it wil force to catch some speed and it will make a noise in the front of the car.... cant explain it but hope you can get the idea of wat might be wrong. thanks for your time.... hope to hear from someone
Manny |
Get the code read and post back for addt'l info.
Re: classic forces to speed up
code is p0300 i think but it says it multiple miss fires so i think its the coil pack. would it be rite to change the coil pack and the spark plugs and the coil module at the same time?
you need someone to check spark who has a lab scope with a kilavolt module with propper adaptors. Then you will know what the coil outputs are and you can change accordingly. As for plugs and wires. I'd do that anyway as part of a tune up.
i have replaced the coil pack and the spark plugs, wires as well..... i have see that the control module has some rust of the connections i have try cleaning it and tryin to starter the car and it did but now i gotta replace the control module.... thank you guys for your time and advise on my car...
If that doesn't get it, have someone with a scope check the crank sensor. Don't replace stuff without testing it. That could end up costing alot of money that isn't neccessary. Except for tune up items.
| The Following User Says Thank You to lilwhitelude For This Useful Post: | ||
mrgaray (02-22-2011)
