Go Back   Automotive Forums Car Chat > Mercury > Mountaineer
Old 02-10-2011, 10:27 AM
jr134 jr134 is offline
Talking Unwanted high pitched sound
I have a 2005 Merc Mountaineer. When traveling at a constant speed (important that it is constant) I get a high pitched sound that reminds you of that high pitched tone you hear when taking a hearing test. If I slow down or if I speed up a mph or two, it goes away --- only briefly though. Once it settles into the new speed, the high pitched sound returns. I thought at first it was my cruise control, but if I shut the cruise control off and hold my foot on the gas as evenly as possible, the high pitched sound is still there.
It is about to drive me more crazy than I already am. Any ideas would surely be appreciated and I will ad your name to my Christmas card list
Thanks so much....
Jack
Old 02-10-2011, 06:42 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Unwanted high pitched sound
Welcome, fellow Iowan!
My initial suspect would be either a rear pinion bearing or a rear wheel bearing. Rear wheel bearings are pretty common, rear pinion bearings not as much. You could try changing the rear differential fluid and see if that changes the sound. If so, then it's probably pinion bearing.
-Rod
Old 02-10-2011, 06:56 PM
-Rod
Thank your for the welcome Rod. And thanks a great deal for the info. I will begin by having the fluid in the differential changed and see what happens. I always seem to get strange and odd ball problems.
Your reply was more than appreciated...
Leganza high pitched sound - brake related eck1039 Leganza 2 08-18-2005 08:37 AM
High pitched sound Shanged '97 - '03 5 03-24-2005 07:00 PM
high pitch sound calchemist Passat 3 02-09-2005 04:27 PM
high pitch sound at 20mph? pathfinder98 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 7 10-16-2004 01:05 PM
High pitched sound from rear wheels.... jacklift Lumina 7 10-15-2004 11:45 AM
