Go Back   Automotive Forums Car Chat > Audi > A4 | S4 | RS4 | A5 > '94 - '01
Old 02-09-2011, 12:36 PM
MNSubbie MNSubbie is offline
Shift Linkage Adjustment??
I am having some issues with my 97 A4Q where it pops out of 2nd gear during acceleration, and is also difficult to get into 1st. This 5 spd has 150K on it
On some Audis and VW's I've had in the past, the shift linkage is adjustable. Is there such an adjustment for my A4 and might that be my problem?? Any/all advice would be appreciated
Old 04-01-2011, 08:37 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: Shift Linkage Adjustment??
Not adjustable linkage on your car, its shift rods like a honda. Check the bushings in the rods and see if they are worn. Also you might have bad trans mounts or front snub mount. Most likely though the clutch is going out.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
The Following User Says Thank You to veedubmechanic For This Useful Post:
MNSubbie (04-04-2011)
Old 04-08-2011, 02:07 AM
damian562 damian562 is offline
My first guess is syncro is going out,could be clutch like first comment but I doubt it..what motor do you have?
