Old 02-09-2011, 11:30 AM
army army is offline
1998 lesabre alighnment
high does anybody know for sure if you can adjust the tie rod end in or out without poping the end out of the knee assembly for alighnment toe in or out,and are the distance from the end of spindle to spindle in front of car the same as distance spindle to spindle in rear of car (saw video on you tube) front alighnment check by azulevo this is real easy to do if tie rod could be aujusted without poping it right out.
Old 02-10-2011, 01:22 PM
Jrs3800 Jrs3800 is offline
Re: 1998 lesabre alighnment
Yes you should be able to turn the inner tie rod..
Old 02-10-2011, 02:08 PM
Scrapper Scrapper is offline
AF Premium User
yes you can ajust tie/rods and there the same way on a park avenue. and also if you got the load levelers on the rear you can also ajust the camber.
The Following User Says Thank You to Scrapper For This Useful Post:
army (02-11-2011)
Old 02-11-2011, 05:06 AM
thanx i will give it a try
Old 02-11-2011, 05:09 AM
thanx guys
